Dual Wheels Stuck together and to hub - Ford Powerstroke Diesel Forum
Old 12-01-2007, 05:25 PM
Hey guys,
Just spent 4 hours in the "Discount Tire" shop watching them try everything to remove the dual wheels off my f-350.....they sent me home with old tires still on one side.......any ideas how to get them off?? and keep them from sticking again?? Thanks!
Old 12-01-2007, 08:28 PM
Send a message via AIM to 6wheelsofjustice
I have had this problem a couple of times and its a pain in the ***, this is prob. not the right way to do it but it works for me. I spray WD40 on the hub where it meets the centerbore of the wheel and kick the tire back and forth while sitting on the ground lol. Its not fun but it has worked everytime. Another time the steel inner's were stuck on my buds 03 we did the same thing but had to use a rubber mallet and eventually went to using a rachet strap to a tree near by. I know they can be a pain. I dont know if this will help but good luck.
Old 12-01-2007, 08:29 PM
take your lug nuts off and go brauf the piss out of it off road. just kiding.
Old 12-01-2007, 08:34 PM
Real Men Love Jesus! <><
well, you could loosen the lug nuts up a little and drive it around in a circle some. Thats what the dealerships do. I had the same problem on my mother in laws VW. Not a dually tho, hahaha, ok funny over. That loosened the wheels up from the hub.
Old 12-01-2007, 09:08 PM
hit the backside of the tire with a BFH, lots of antiseize when putting back together
Old 12-01-2007, 09:43 PM
The Fat Mod
This will work if you are haing troubles.
Old 12-01-2007, 10:10 PM
Is it even worth it???
Mines not a dually.. but I recently had the same problem with the reat tires on my truck.
The solution, brought to me by a coworker who used to work at a tires shop was surprising.
Take a small BFH (I know contradiction in terms... but we used a 4lb short handle sledge) and hit the tire right next to the bead. The hammer should actually contact the rubber first, and then bounce off of the metal. I know... sounds like you will damage the rim, but if done right, the tire takes the shock, and the hammer hitting the rim jars them loose.
I had no damage on my aluminum rims from doing it this way.
Old 12-02-2007, 04:56 AM
We had the same problem with, we rigged up a small air bag(we have a truck parts store) and put it between the duals and got the outside off first then did the insde.
Old 12-02-2007, 05:31 AM
Almostdunfukinwidit
We had the same problem with our 99 dually at work i beat on the tire with a BFH for almost a half hour before it came off
Old 12-02-2007, 05:46 AM
Spray some good penetrating oil(PB blaster or ZEP) around the hub area and either use the "Ford Tool"(BFH) as mentioned earlier or loosen the lugs up and drive it around in the parking lot. After ya get 'em off, clean the hub mating surfaces real good with a scotchbrite or sand paper and the coat it liberally with anti-seize. I have had this happen several times.
