Can I run jet fuel - Page 2 - Ford Powerstroke Diesel Forum
post #11 of 30 Old 12-01-2007, 09:27 AM
duct tape & zip ties
bigcountrysg's Avatar
Originally Posted by duck View Post
I don't think it would be a good idea, but it can be done. What type of fuel is it. There are several varieties, each with different characteristics. We have certain restrictions with running anything other than JP8 in our aircraft.
The military uses JP-5 and JP-8 to run Humvees, 5-ton corgo trucks, Generators, and pretty much anything else that runs on diesel.
But think about those engines, Cummins, Gm 6.2 and 6.5 and the 4 cylinder diesel engines in the mep-5 generators. They all have a different injection system. Then what is on our trucks.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #12 of 30 Old 12-01-2007, 09:30 AM
RedneckGirl's Avatar
Quoted: 27 Post(s)
My Ex filled my ex with jet fuel that came out of a plane that he worked on without my knowlege. I wouldn't recommend it. Part of what happened to me is due to the fact the fuel had some water in it, but I had told him NO from the beginning. If it was meant to run on jet fuel my Excursion would have wings...
There are no positives to running jet fuel in a vehicle not made for it. Why take the risk? 3 fuel filters and a lot of headache later my truck finally got back to running normally.
~Shayna
2008 6.4L 4X4 Lariat
6.4L w/SCT Livewire, Deleted, and loved! About to hit 200,000 miles!
RIP 2003 7.3L Limited Excursion 4X4 & 2007 6.0L Lariat FX4
RedneckGirl is offline
post #13 of 30 Old 12-01-2007, 09:33 AM
Turnin' JP8 into noise!
duck's Avatar
Here is some info on the different types of jet fuel:
AVIATION TURBINE FUEL (JET FUEL)
CIVIL JET FUELS
Aviation turbine fuels are used for powering jet and turbo-prop engined aircraft and are not to be confused with Avgas. Outside former communist areas, there are currently two main grades of turbine fuel in use in civil commercial aviation : Jet A-1 and Jet A, both are kerosene type fuels. There is another grade of jet fuel, Jet B which is a wide cut kerosene (a blend of gasoline and kerosene) but it is rarely used except in very cold climates.
JET A-1
Jet A-1 is a kerosene grade of fuel suitable for most turbine engined aircraft. It is produced to a stringent internationally agreed standard, has a flash point above 38C (100F) and a freeze point maximum of -47C. It is widely available outside the U.S.A. Jet A-1 meets the requirements of British specification DEF STAN 91-91 (Jet A-1), (formerly DERD 2494 (AVTUR)), ASTM specification D1655 (Jet A-1) and IATA Guidance Material (Kerosine Type), NATO Code F-35.
JET A
Jet A is a similar kerosene type of fuel, produced to an ASTM specification and normally only available in the U.S.A. It has the same flash point as Jet A-1 but a higher freeze point maximum (-40C). It is supplied against the ASTM D1655 (Jet A) specification.
JET B
Jet B is a distillate covering the naphtha and kerosene fractions. It can be used as an alternative to Jet A-1 but because it is more difficult to handle (higher flammability), there is only significant demand in very cold climates where its better cold weather performance is important. In Canada it is supplied against the Canadian Specification CAN/CGSB 3.23
MILITARY
JP-4
JP-4 is the military equivalent of Jet B with the addition of corrosion inhibitor and anti-icing additives; it meets the requirements of the U.S. Military Specification MIL-DTL-5624U Grade JP-4. (As of Jan 5, 2004, JP-4 and 5 meet the same US Military Specification). JP-4 also meets the requirements of the British Specification DEF STAN 91-88 AVTAG/FSII (formerly DERD 2454),where FSII stands for Fuel Systems Icing Inhibitor. NATO Code F-40.
JP-5
JP-5 is a high flash point kerosene meeting the requirements of the U.S. Military Specification MIL-DTL-5624U Grade JP-5 (as of Jan 5, 2004, JP-4 and 5 meet the same US Military Specification). JP-5 also meets the requirements of the British Specification DEF STAN 91-86 AVCAT/FSII (formerly DERD 2452). NATO Code F-44.
JP-8
JP-8 is the military equivalent of Jet A-1 with the addition of corrosion inhibitor and anti-icing additives; it meets the requirements of the U.S. Military Specification MIL-DTL-83133E. JP-8 also meets the requirements of the British Specification DEF STAN 91-87 AVTUR/FSII (formerly DERD 2453). NATO Code F-34.
06 F350 Harley Edition
Crew Cab Long Box
Auto Meter Ultra-Lite Gauges
MBRP T304 SS 4" Turbo Back
AFE Stage II intake
Zoodad
Fluidampr
B&W Turnover Gooseneck Hitch
Xtang Revolution Tonneau Cover
Line-X w/ removable Carpet Bed Kit
2.5" Leveling Kit
BFG A/T KO 285/65/20R
Recon Smoked Cab and Tail Lights
If you ain't CAV, you ain't sh&#!!!
duck is offline
post #14 of 30 Old 12-01-2007, 09:38 AM
duck's Avatar
All military vehicles/generators are required to be able to run on JP5/JP8 as an emergency or primary fuel because it's the same fuel run in our aircraft and tanks. They run diesel most of the time, though.
Crew Cab Long Box
AFE Stage II intake
Zoodad
Fluidampr
2.5" Leveling Kit
duck is offline
post #15 of 30 Old 12-01-2007, 09:51 AM
WILLIAM LORCH's Avatar
Send a message via MSN to WILLIAM LORCH
Hi there from a Retired A&P mechanic :: YES YES YES U can add some lubricant to it ie Staydine etc Power service a little oil if it ake you fel better... Years ago I was hte chief Inspector for Mississippi vally airlines( A regional for UNITED ), Now every night we would drain the sumps on the aircraft. I ran my benz for over 3 years on the stuff ,also burned it in a kerosun heeter in the shop..Good stuff Now you do as you wish however i have about 5 yrs experence in running jet fuel in diesel engines... NO PROBLEMS>>>> BILL
WILLIAM LORCH is offline
post #16 of 30 Old 12-01-2007, 11:48 AM Thread Starter
Quoted: 6 Post(s)
Good stuff. Mississippi Valley. I used to fly for Air Wisconsin. Quit last year. Thanks for all the info. I will probably try a small amount mixed in with the diesel and see how it runs . The truck is for sale anyway..HAHA ...
RRRDAD is offline
post #17 of 30 Old 12-01-2007, 01:01 PM
mrnecsteve's Avatar
I am curious. Why do you drain the vents or sumps in jets ? What is the scoop?
mrnecsteve is offline
post #18 of 30 Old 12-01-2007, 01:11 PM
Desert Shield/Storm Vet
vitalidle's Avatar
Drains the water off and any contaminents.
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #19 of 30 Old 12-01-2007, 01:19 PM
Cynic
Dirk's Avatar
I ran jp-4 in a 6.9 IDI. I wouldn't do it in a powerstroke.
Best Car & Motorcycle Insurance | Auto/Moto Protection Today | FREE Trade-In Quote
Voluntary Banishment: Knowing when to leave.
Total Diesel Performance\Unlimited Diesel Performance\Diesel Innovations\BTS\Terminator Engineering\Swamp's Diesel Performance\Black Widow Diesel\Calvert Racing
Dirk is offline
post #20 of 30 Old 12-01-2007, 01:30 PM
Let's go B's!!!!
Southpaw's Avatar
Feedback Score: 5 reviews
Man that ain't right.
I can see a future post form a powerstroke.org rookie now......"The previous owner must have been p!ss!ng in the fuel tank or something, HELP, How do I fix it?"
Anyway looking at the risk vs. reward....Not worth the chance IMHO.
Good Luck
Chris
2002 Crew Cab Long Bed
4" BDS, 35x13.50 Cooper STT on 20x10 Black Rockstars, and other stuff.....310,000 miles and counting...
2 Thessalonians 3 v.6-15
Southpaw is offline
