U-Joint Indentification - Ford Powerstroke Diesel Forum
Old 11-30-2007, 09:55 AM
I'm having a single piece rear driveshaft with double cardan joint made to replace my 2-piece factory shaft... to many vibes with the factory setup.
Does anyone know how to identify the t-case and rear end yokes? I'm not sure if they're for 1350 or 1410 series u-joints. Need to figure this out before ordering the shaft. My truck is a '02 F350 Crew Cab SRW 4x4 with factory off-road package and auto trans. Thanks
Old 11-30-2007, 09:59 AM
duct tape & zip ties
There are several differnt u-joints for our trucks. You will have to measure your wheel base to find out which ones yours are.
Old 11-30-2007, 10:23 AM
Should be 1350 on the 250 and 350 trucks. 450 and up will have 1410 series u-joints
Old 11-30-2007, 10:30 AM
Thanks guys
I believe it's a 156" wheelbase (crew cabe + short box)... the driveline shop told me it would have either 1350 or 1410. I was thinking that the duallys might have had 1410, or maybe all F350's had 1410. There must be a joint cap diameter, or dimension across caps that veries between 1350 & 1410 series.
Old 11-30-2007, 10:35 AM
Found it...
series width cap dia
1310 3.219 1.062
1350 3.625 1.188
1410 4.188 1.188
Old 11-30-2007, 10:36 AM
There is also a 1330 series it has 1310 cap sizes but the cross is wider. Goodluck.
Old 11-30-2007, 10:45 AM
Billavista Tech is pretty much spot on.
Pirate4x4.Com - Extreme Four Wheel Drive
