Does this sound like a good buy? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 01-30-2013, 07:03 AM Thread Starter
I am looking to buy this truck and this is the description the guy gave me when i asked him about the truck.
" I'm asking 11 for the truck . It doesent have any major mechanical problems . I just had a steering box put in and new hoses and a new tie rod put in around Christmas time . New brakes all around new transition fluid and it has an awesome stereo system ! If you wanna take a look let me know Nd I can have my dad open the truck up so you can look at it ! Oh and I have a lift kit that will come with the truck but it does new a little tlc some time every weekend will really tie this truck together "
Year is 1999 and 185xxx miles.
Just wanted yall's opinion on it
ID:	60578   Click image for larger version
ID:	60586   Click image for larger version
delifresh is offline
post #2 of 13 Old 01-30-2013, 07:05 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
WHAT DOES IT NEED? DID HE SAY?
2000-7.3L is offline
post #3 of 13 Old 01-30-2013, 07:06 AM Thread Starter
No he has not replied about that yet.
post #4 of 13 Old 01-30-2013, 07:08 AM
2000-7.3L's Avatar
Figure out what it needs and let us know, Its hard to tell by the description, If its mechaniclly sounds and not rot sounds like a good deal
post #5 of 13 Old 01-30-2013, 07:14 AM Thread Starter
it has minimal rust in the typical ford rust spots.
post #6 of 13 Old 01-30-2013, 07:16 AM
2000-7.3L's Avatar
Ask about glow plugs? Injectors? Turbo? HPOP? if and when these were changed out
post #7 of 13 Old 01-30-2013, 09:14 AM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 19 Post(s)
That was hard to interpret towards the end. Curious if its an early/late 99.
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
post #8 of 13 Old 01-30-2013, 04:37 PM
Maybe he will take less if you offer to let him keep the horns
Pipewrench is offline
post #9 of 13 Old 01-30-2013, 05:12 PM Thread Starter
"some issues that i began to tackel like typical rust on the cab corners the drivers side is finished and sanded smooth and painted the passengers side needs to be sanded and painted no biggie but the seasons changed on me too quick to get to it. the only mechanical issue would be the carrier barring is warn and could be replaced... less than 100 bucks. just little things here and there. the motor is solid and i have had no issues with the turbo or injectors or turbo the turbo can boost 35psi and still spools like a champ"
this is the second time he responded to me
i am not sure if it is early/late 99
and pipewrench i like the horns
post #10 of 13 Old 01-31-2013, 04:50 AM
dieselcrawler's Avatar
Quoted: 23 Post(s)
Re: Does this sound like a good buy?
If its hittin 35 psi its got some kinda tunes which IS NOT MENTIONED. That is some info you need. If the truck is seeing 35 psi is he running it hard? I have NEVER seen over 28-ish psi in my red trk with DP Tuner on 120 race setting.
Not a deal breaker just need more info to feel good about it. I prefer to buy stock trks w/o tunes and mod myself. In stock form these trks are goverened back to the point they cant hurt themselves. Tunes changes all that. 35 psi is double what they make stock.
Sent from my SCH-I200 using AutoGuide.Com Free App
Greg
'99 E350 DRW Stahl 11' util box van, 7.3 PSD, stock. 138k SOLD
'00 F350 extcab, 9' utility bed, dually 228k
E'99 F250 extcab, S/Bed 211k. Sidelined due to motor issues.
'00 Excursion Limited, 7.3PSD 294k
'84 Chevy K-30, 6.2L TD, woods/trail beater. 141k
Semper Paratus
dieselcrawler is offline
