Fuel gauge ain't worth a darn!
Everytime I fill up the fuel gauges drops to complete empty and my fuel light comes on. I know I've got plenty of diesel in the tank (of course), but it's annoying to have to explain that I've got plenty of fuel in the tank whenever someone rides with me.
Is there a fix for this problem? I'd like to use my fuel gauge instead of having to rely on my trip meter to tell me when to fill up. Also, today when I filled up it showed I had just over 1/4 tank left. I put 25 gallons in a 28 gallon tank. It just doesn't work for sh!t!!! |
Does the gauge stay on empty or does it eventually read correctly? IF it is staying on the low end, it sure sounds like your float in the tank is stuck on something. Many have taken a large rubber mallet and given the side of the tank a good smack or two and see if this will free it, otherwise it is time to drop the tank. While you have it down you might as well do the tank mods too!!
The thing that gets me is the gauges really isn't that predictable. It seems to have a mind of its own at times. What kind of tank mods are available, how much do they cost, and what are the benefits of these mods? Also, how hard are they to perform? I've only dropped a tank in one other vehicle I've owned, so I can do it, but I'm not a pro by all means. |
Simple fix new fuel tank level sending unit. Takes about an hour to install it. You have to drop the tank. The part is around 350 from a dealer.
There is nothing in the tank for the fuel tank level sending unit to get stuck on. The tank is completely open inside of it. When you smack the side of the tank what your trying to do is get the float to go back up to the top of the tank. But it does not always work. |
From my understanding they don't go bad that often. I got mine from the local junkyard. I got the whole tank for 150 out of a 2002 F-250 crew cab shortbox. Just so happens I have a 2002 f-250 crew cab short box. All I used was the fuel pickup tube assembelly. Which I have yet to have any problems since I did the repair.
Either that or does anyone have one they'd like to part with? |
The junkyard by me was like you got to take the whole tank. They did not want an incomplete tank. I figured ok if I ever damage the tank I have an extra one on hand.
That's true, but I don't have any place for an extra tank right now. Wonder if I could just sell them the tank back haha
Well I think the place I went to gave me the tank but charged me 150 for the pick up tube. If you find one tell them they can keep the tank. Or clean the tank real good and scrap it. do you have the metal tank or the plastic tank.
