High pressure oil crossover - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-28-2007, 07:44 PM Thread Starter
fordmike1's Avatar
I this mod worth doing? If so who sells this? I have an 02 7.3. My truck just feels like it lays over once it gets into the top of second and all thru third and then when it goes into OD and I back out of the throttle a little it feel like it pulls alot harder. I never get an CEL. I know that this is not going to fix my problem but it would equalize the pressure and that is better right? I just had the trans rebuilt with a billet torq.,shift kit,six pinion planets,four pinion OD planet,and the bigger upgraded boost valves. While I was having the trans redone I installed a 4" FBD turbo back exhaust with muffler and the truck allready has the superchips max microtuner installed. Any suggestions as to what could be going on with this. Thanks Mike.
02 crewcab Lariat 4x4 7.3l PSD
4" farmboy exhaust with5" AFE tip
Airaide air filter system
superchips programer
Autometer gauges (boost,trans,EGT)
Amsoil (engine,t-case,diff's)
fully built trans w/billet torq
Procomp 4" lift w/MX6 shocks
Procomp Xtreme AT tires 315/75-16
Hopeing to Destroke it someday
99 Eddie Bauer Expedition 4x4 5.4l gasser
Completely stock
01/20/2013
Change we all can belive in.
YES WE CAN ! ! !
NO Way, No How, NO BAMA !!!
fordmike1 is offline
post #2 of 3 Old 11-29-2007, 01:29 AM
Here is the one I got from ITP!
KCM S.S. HPX Line (99-03)
Early 99 F350 4X4 6SPD Crewcab Dually
6637 Air Filter, MKO 4" turbo back to 5" straight pipe Exhaust 6" tip, Isspro gauges Pyro, Boost, Watertemp, DP Tuner, Stock 40tow,60tow,80econo, 120race, KCM S.S. HPX line, ITP Overboost Annihilator.
IDPisan is offline
post #3 of 3 Old 11-29-2007, 03:57 AM
Powerstroke Junkie
NCHornet's Avatar
Many people make them, some metal lines, some braded and some rubber. The crossover line will smooth out idle and quite the beast a little. Most say it is worth doing. It is one of my future mods. I believe your problems could be taken care of with good tuning from someone like TW or Jody.
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
