Clutch sensor kill switch write up
Hey guys i just wired up a kill switch that was fairly simple and easy and hopefully prevents an attempt to steal my truck. And to the mods...maybe this could be sticky worthy???
What you will need -2 Position switch -16 gauge wire -2 Butt connectors -2 Female spade connectors -Tiny hands would have helped ![]() First you reach up and find the clutch position sensor, its a black box about 5inX2inX1in and its on a piston connected to the clutch. Heres some pictures of it ![]() ![]() ![]() Theres a gray connector on the top of it, this is the connector you need to get out. In order to do that you pull the box forward toward the clutch and it will allow the box to spin around so you can access the clips on the side of the connector. ![]() This is kinda of the PITA part mostly because of the strange position you have to be in to get up there but what worked best for me was a flat head screwdriver and just work each side up Once you have it out there are 4 wires, the white with the pink runner is the one you want to cut. I just cut it in the middle between the connector and where the insulating sleeve starts ![]() Then just strip the two ends and then butt splice the two pieces of wire on each end then you can put the gray connector back in to the sensor, once its back in then you figure out where you want to mount the switch so you can cut the wires to length and crimp on the female connectors to the end and connect them to the switch of your choice. I chose to mount mine to the left of the parking break release just up under the knee panel out of sight but easily switched if you know its there. ![]() ![]() So when its flipped on it starts just the same as normal, but when its flipped off it acts just the same until you go to start the truck it will not even turn over, as if you didnt push the clutch down. So basically if anyone wants to start it they wont unless they find the switch, which isnt hard but its better than nothing i suppose. Anyway i hope this helps especially with all of the recent thefts i have seen on here. Good luck guys and if you have any questions feel free to ask |
Re: Clutch sensor kill switch write up
I like this idea a lot! Keeps us from wasting a spot on our 6 pos switch for a no start tune.
If I had any worth here if defiantly reccomend this for a sticky! I got another project Friday now lol Sent from my DROID BIONIC using AutoGuide.Com Free App |
I like it. Good job!
Looks like I have a new mod to do. Thanks for the writeup!
No problem
![]() Hell it works so good sometimes it stops me from starting it and i get pi$$ed cause i think somethings wrong |
excellent Ramm..
I'm gonna see where that wire goes to. Maybe an easier access point, if any. But, i'm tackling the "RAMM MOD", or "STEIN-STILL mod' |
i did it once and it was a huge PITA because those 44s dont turn unless your moving with the truck on
I think I might do this over the weekend.... One of my buddies from the CCR just got his truck back from it being stolen...his was an auto though. I dont want my girl disapearing
The other key is to not tell the GF about it and watch her freak out lol
