Anythng else while turbo is off? - Ford Powerstroke Diesel Forum
Old 11-28-2007, 08:10 AM
So when i get my turbo off ( I only have the clamp for the Up Pipes I just cannot get it off) but when i get it off is there anything else i should do while I have access to all of this? I cannot wait to get my turbo from beans
Old 11-28-2007, 08:38 AM
John Wood Nut Swinger
Take the pedistal off and replace the O rings under it. If the up pipes are leaking now is the time to fix that as well. If you ordered a set of O rings it usually comes with two of each size just for that reason.
Old 11-28-2007, 09:40 AM
I rebuilt my turbo a couple of months ago, and now my ebv solenoid is leaking. I am replacing it with the delete pedistal. I guess the moral is...You never know. Rod
Old 11-28-2007, 09:52 AM
Get a rebuild kit for the pedistal. or just tap it and put a pipe thread plug in it.
Old 11-28-2007, 09:54 AM
Make sure when you put the V band clamps back on you use anti-sieze on them. You will thank my later on down the road.
Old 11-28-2007, 10:00 AM
Send a message via AIM to submariner Send a message via Yahoo to submariner
how often should you do think maintanence. i have 130K on my '02 7.3
