Fuel bowl drain o-rings - Ford Powerstroke Diesel Forum
Old 11-27-2007, 01:04 PM
Had the usual O-rings start to leak on the bowl drain. Ford wanted 44.00 for 2 o rings and 57.00 for the assembly. I went to the International dealer and they robbed two orings from an assembly part # 1823565c1 (orings) . The cost was 3.28 .. the assembly is not the correct assembly for the ford but it has the same orings. Also noticed with the old orings that they have been deformed abit on the side that comes in contact with the valve. If you are in a pinch you could probably turn the orings around and it may seal that way. good luck...
Old 11-27-2007, 02:58 PM
John Wood Nut Swinger
I know guys that have been in the middle of now where and they turned them around. It works but only for a few months. You can also use #90 O rings from your local plumbing section at a hardware store. I have a set in my fuel bowl that have not leaked in 3 years.
I wish my IH dealer was like yours. My IH dealer does not want to deal with Ford guys.
Old 11-27-2007, 05:09 PM
Man I just had to buy the whole assembly today from ford because no one around had them. I never even thought about the IH dealer 5min away...
Old 11-28-2007, 02:42 AM
Powerstroke Junkie
any hydraulic shop will have the Viton rings that you should use. Anything more than a couple bucks and you got ripped. Check your yellow pages for a hydraulic shop in your area.
Old 11-28-2007, 06:20 AM
A quick bandaid for this would be to put a small piece of hose on the drain and plug it with a bolt and hose clamp. Obviously dont let Dodge or Chevy owners see you do this but it will work for a temporary fix..
Old 11-28-2007, 08:01 AM
It won't hold the pressure of the system for very long. So just keep your eye on it.
One of the old school ways to set the FPR was to clamp a piece of hose on the outlet and put a gauge on the other end. Open the valve and you have the pressure in the system being read. Only it had a habit of popping off between 60-65psi. What a mess it makes. Then I got the notion to put the outlet on the lathe and machine barbs into the outlet nipple. No problems from then on with my pressure gauge popping off. Man was that a long time ago, back when I was tweaking on my '95 PSD.
Old 11-28-2007, 09:32 AM
lukecline
Guest
Posts: n/a
lol i had to do that just the other day. What sizes are the O rings for an early 99, anyone know off the top of their head?
Old 11-28-2007, 09:51 AM
Early 99 is the same as the late99-03, 1/2"od x 1/4"id x 1/8" thick. I get them from ACE hardware and Orchard Supply Hardware, they are a #90 O ring from the plumbing department. Others have said they can be had from a hydraulic ship, but not from my local Parker store. I have herd tell of a #202 O ring as well. You will have to see what you find in your area using the size.
Write up here: Fuel Filter/seperator drain o-ring replacement...my first write up - TheDieselStop.Com Forums
Old 11-28-2007, 10:20 AM
Over the holiday wkend we were in AZ and mine was leaking in the A.M. but after warm-up it stopped, now I'm home (so cal) and no more leak at all do you guys think I should go ahead and change them anyway?? Thanks to Strokin Early 99 (Howard) & NC Hornet for all your help I got the O-rings from Ace-#90 just haven't changed them yet cause the leak stopped
Old 11-28-2007, 04:15 PM
Yes, I would change them even though they are not leaking now. It is a matter of time, very near time it will leak again.
