Climate control switch not working - Ford Powerstroke Diesel Forum
post #1 of 13 Old 01-28-2013, 06:21 AM Thread Starter
simone0414's Avatar
Presently it will only blow air out the defrost & the vent. It blows out both at the same time. No matter what setting I put it on this is what I get. Have no idea how to trouble shoot this problem. Is it most likely the switch?? If so where is the best/cheapest place to buy one? Or should be junkyard hopping??
Any help is greatly appriciated>
2001 f-350 ext.cab. 7.3 auto non dually. 262k miles. New HD tranny at 67,000 miles. Boost, EGT, Tranny temp gauges. 04/10 DIY check valve VO conversion. 20 plate FPHE,Fass HPFP set at 70 PSI,TIH, 10 micron spin on filter with coolant wrap, 150 micron prefilter, hrydraforce purge valve, 40 gallon greasecar tank with hotfox, SS braided hose to heads, Oil temp, pressure & fuel level gauges. 110K miles on grease.
Monitoring with Torque.
simone0414 is offline
post #2 of 13 Old 01-28-2013, 10:10 AM
What I do know is that its controlled by vacuum as to where it blows from. So your problem could be in the vacuum system. I would start with the switch as its a lot easier to try that. I think the local parts houses have them. If you cant find one, I have one laying in the garage that id sell you. Shoot me a PM if youre interested.
2001 F350 SRW CC 4WD LB
ZF6 w/ Southbend, 220k, DIY Intake, WW,NonEBPV Pedestal, CCV Mod, Gauges (Boost, Pyro), 2in Leveling Kit, 4" Straight MBRP, AIH Delete, 2-12" Kicker Comp's, Pioneer Amps
2001 F350 DRW EC 2WD (Rolled Over)
2000 F550 CC 2WD
Automatic, Jasper 4R100 w/Derale Pan & 6.0 Cooler, DIY Intake, AIH Delete, 4" MBRP,
Schnot is offline
post #3 of 13 Old 02-12-2013, 05:10 PM
Any resolution?
2005 F350 4X4 SRW, Crew Cab King Ranch.
4" Lift-35x12.5R20
4" Turbo Back Exhaust (straight pipe)
Banks Intake Elbow w/Pipe
EGR Delete (waiting on install 9/6/12)
Dashboss w/EGT, displayed on mounted iPod
Unknown Program (assumed stock)
jsalty is offline
post #4 of 13 Old 02-12-2013, 05:58 PM
vacuum pump maybe.
2003 F250 7.3 CC SB FX4
TS Chip Tuned by Tony Wildman
4" MBRP Turbo Back Straight Pipe
Driven Diesel Regulated Return
International Bellowed Up-pipes
K&N Intake W/ 6637
Transgo Shift Kit
ATS Ported Turbo Housing
Wicked Wheel 2
EBPV Delete Pedestal-High Flow Outlet
3 Gauge Pillar Pod
Viper Remote Start w/Turbo Timer
potbss is offline
post #5 of 13 Old 02-13-2013, 04:21 PM Thread Starter
simone0414's Avatar
Well the vacuum pump was bad so I ordered a new one. Installed it yesterday & it is working but air still only blows through the defrost & vents.
What else could be going on here??
post #6 of 13 Old 02-13-2013, 04:39 PM
Check the vacuum lines. I think they come in near the passenger side floor. See if a line got disconnected.
K&N Intake W/ 6637
Transgo Shift Kit
Wicked Wheel 2
3 Gauge Pillar Pod
potbss is offline
post #7 of 13 Old 02-13-2013, 06:47 PM
Open your glove box and release the stops so it will fold forward. Check to see that the lever on the left side is not being hindered by something that may be in the way.
huntnphool is offline
post #8 of 13 Old 02-15-2013, 11:01 AM
I found my issue. A squirl found its way under my hood and figured it would chew chew chew.
Rewired all that I noticed being chewed replaced all chewed vacuum lines and now I need to find out why the windshield squirters still won't work.
More disassembly required.
Thanks all!
Sent from AutoGuide.com App
4" Lift-35x12.5R20
jsalty is offline
post #9 of 13 Old 02-15-2013, 12:32 PM
floorboy's Avatar
This works.
Squirrel Launcher - YouTube
Originally Posted by bjs505 View Post
Of course I'm handy under the hood, I currently own a cummins.
2010 F350 CCLB Cabelas Edition
No Limit cai, Mini Maxx, 5" turbo back Flo Pro, Sinister egr delete, Sinister coolant filter, Cat EC-1, PTP shift solenoid. 20x9 +18 XD Monsters
01' 7.3 CCLB, 6637,wicked wheel G2, HPX, PHP Hydra, MBRP 4" Turbo back, Bellowed uppipes, Stancor gpr, 6.0 cooler, Fpr, Glow shift exhaust, pyro, trans, 203*/billet housing/ Cat EC-1, '07headlights/05' grill, Oh8' gate.
78' F350 "dumpy" old school
floorboy is offline
post #10 of 13 Old 02-15-2013, 01:23 PM
That is a great use for a clay launcher. I am resorting to a .22 for revenge.
4" Lift-35x12.5R20
jsalty is offline
