Does My 99 Powerstroke have a block heater - Ford Powerstroke Diesel Forum
post #1 of 10 Old 11-26-2007, 10:35 AM Thread Starter
Hi,
I just bought a used 99 ford powerstroke. Did they come with block heater standard? If so where would I look to find it. I don't see any obvious cords with a plug in end. I'm in Montana and the mornings have been single digits and the truck has been very hard to start. Someone told me to put synthetic motor oil in and that would help, but I'd like to get a block heater if it dosn't have one.
Would this be a do it yourself job or should I have it installed professionally?
Also does anyone know how to get the display for the stock radio fixed. The radio with CD player works, but the display doesn't light up.
Thanks,
proskier is offline
post #2 of 10 Old 11-26-2007, 10:41 AM
John Wood Nut Swinger
strokin_early_99's Avatar
The plug should be on the driverside tucked up under the bumper. At least mine was there when I got it.
(Born on 11-20-98) F350 CC LWB 4X4
north of 480hp and south of 13.7sec
Bored with current setup
Family of 5 saved by Grace.....
Sponsored by Left Coast Diesel in Concord, Ca
Anything BUT Conservative Performance
strokin_early_99 is offline
post #3 of 10 Old 11-26-2007, 11:39 AM
BIG TRUCK, SMALL DRIVER
pipelayerjdh's Avatar
If you can't find the plug, look above the oil filter for this wire and trace it out.
Derrick
'97 F-350 "FORDOR" 4X4 (Dually Conversion, Shackle Reversal, Technicooler , Auto Meter Gauges, 4" DIY Dual Exhaust w/ '08 tips,
, Wicked Wheel 2, 360 thrust bearing, Homemade E-fuel conversion, Wildman Chip,
) 230K and counting...
pipelayerjdh is offline
post #4 of 10 Old 11-26-2007, 11:42 AM
strokermann's Avatar
i think they all came with one installed from teh factory and then i think in 03 it was an option but the element was still there. if you don't have the cord you will still have the element. and all you will have to buy is the cord and its a 5 min hook up.
CB Radio- General Lee
7.3l 99 f-250 SD
4 INCH TURBO BACK TO 6 INCH MITER CUT STACKS CURIOSTY OF GRAND ROCK AND COWBOY DIESEL PERFORMANCE.
TS 6 POSTION CHIP. stock,high idle,50,75,100,140hp.
strokermann is offline
post #5 of 10 Old 11-26-2007, 11:45 AM
Powerstroke Junkie
NCHornet's Avatar
After you find the cord, then do the Marinco mod it will be one of the best non performance mods you do to your truck. I think there are pics in my sig. And yes switching to a lighter weight oil in cold climates will help the truck a lot!! As will a properly operating GP system, how to test them is in the maintenance section.
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #6 of 10 Old 11-26-2007, 12:26 PM Thread Starter
Thanks guys!!!!! I found it. Traced the cord, it was wadded up near the radiator and trans cooler.
proskier is offline
post #7 of 10 Old 11-26-2007, 02:57 PM
Powerstroke Junkie
NCHornet's Avatar
Like I said if you use it a lot, you don't say where you live, do the Marinco mod, it is very handy!!
NCH
Ford AIS/ BTM, FTVB
KMC Wheels x 4
NCHornet is offline
post #8 of 10 Old 11-26-2007, 06:03 PM
Stroked's Avatar
what is the marinco mod?
01 just the basics
05 studded, deleted, swamps ficm, innovative tuned
SOLD
99.5 stealth dual pumps, hybrids, and BFH
TOTALED
Stroked is offline
post #9 of 10 Old 11-26-2007, 06:11 PM Thread Starter
I looked at your pics. That's a pretty cool idea. Very clean looking. I am in Montana
proskier is offline
post #10 of 10 Old 11-27-2007, 02:20 AM
Powerstroke Junkie
NCHornet's Avatar
Then I would definetly do the Marinco mod!! You will get real tired of reaching up inside your grill to plug and unplug your truck.
NCHornet
NCH
Ford AIS/ BTM, FTVB
KMC Wheels x 4
NCHornet is offline
