Clutch sensor kill switch?
I had a thread about this a few days ago and i just had a thought but i have no idea where it is, but could i put a kill switch on the clutch sensor that prevents the starter from cranking unless the clutch is pressed.
My question is where is that sensor, is it right up by the clutch or is it in the engine bay or what? |
My truck will not start without the clutch pressed...
Exactly that what i want, i want to be able to shut off the sensor that tells the engine the clutch is pressed so that even when a thief presses the clutch nothing happens but when i flip the switch it works just like normal
there's a few ways to disable it...you can remotely mount a relay between the starter solenoid, then run the switched 12v into cab, disabling the power to relay. or can go the knarly route...
SpringerPop's Disabler Think, our trucks sensor is the electric hechanism, located on the m/s shaft...theres a few wires i guess you can probe around, and see what 2 you need to connect to. |
but the reason i want to do the clutch kill switch is when you dont have the clutch pressed the truck doesnt do anything at all and i figured this sensor is basically a starter kill switch already so why not use it instead of screwing with engine wiring. Im looking for a theft deterrent, not a 100% stop all theves thing. Just something better than nothing
Any ideas guys?
I wonder if this will work... and what would happen if you try to bump or push start it.
Well basically it would be a switch that interrupts the sensor that tells the engine that the clutch is pressed and allows the engine to crank. With the switch off it will be like the clutch isnt pressed which wont let the engine crank i just havent been up there to look yet so i thought id see if anyone has had success doing this
So, what you are asking for is where the clutch switch is? If you are asking for your 7.3 monster there, the clutch switch is on the inside of the cab and rides on the clutch push rod. It is actually a set of 2 switches combined into one unit. One that determines if the clutch is all the way pushed (for starting) and the other tells it if the clutch is partially pressed (for disengaging the cruise control). Both of these mount in one switch and the switch is removed by pressing the sides of the electrical connector together to disconnect the harness, then remove the cover by pressing the sides of that cover together and removing it. The switch can then be rotated and removed from within the cab if necessary.
The switch rides freely on the rod and if you pull it out a bit, you can rotate it for easier access to the harness. You could very easily put in a secondary switch to act as a starter kill for what you are looking for. It would have no effect on bump starting though. Hope this is what you were looking for... |
Basically i want the sensor that tells the starter the clutch is pressed to have an on and off switch so that when i turn it off its as if the clutch is not pressed even though it is, thus foiling most thefts. When i flip the switch on, the sensor will act just as it does normally like when it rolled off the assembly line |
