WOT Lag issues - Ford Powerstroke Diesel Forum
post #1 of 18 Old 11-22-2007, 05:24 PM Thread Starter
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
WOT Lag issues
I noticed this about my truck tonight. At anything less than 3/4 throttle, the truck pulls great. If I go any more than that in high gear, the boost level goes up, the EGTs go up, but the truck doesnt go any faster. It lags, and you can feel it. If you let off, it will put you back in the seat again. What could cause this? I also get a SES light, and then the truck starts to shudder a little as you let off the throttle completely. I havent run a code check, but my previous codes on the truck when it did this were a 1211, and one for the EBPV, and the EPS. Neither of which my truck has. I also pulled an overboost code, but I never saw above a 20 PSI max boost.
On another note, when I set my Cruise Control, I get a bad shudder out of the truck as it tries to keep speed. What can cause this? No SES light is on, and when I hit the brake, or turn off the cruise, it immmediately stops, and it accelerates fine by me pushing the throttle. What is causing this?
Thanks in advance guys!!!
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #2 of 18 Old 11-22-2007, 06:09 PM
John Wood Nut Swinger
strokin_early_99's Avatar
My old BD chip use to shutter like that with the cruise on. If you pulled an overboost code then you need a boost fooler. I have herd of trucks registering different boost levels when it set an overboost code.
(Born on 11-20-98) F350 CC LWB 4X4
north of 480hp and south of 13.7sec
Bored with current setup
Family of 5 saved by Grace.....
Sponsored by Left Coast Diesel in Concord, Ca
Anything BUT Conservative Performance
strokin_early_99 is offline
post #3 of 18 Old 11-22-2007, 06:10 PM Thread Starter
Doesn't Even Care
Quoted: 69 Post(s)
Thanks Strokin' I guess I will order one tonight.
Nick
"The Mistress"
post #4 of 18 Old 11-22-2007, 06:45 PM Thread Starter
Doesn't Even Care
Quoted: 69 Post(s)
I just read something where the 97 and early 99 trucks defuel at 14-17 pounds of boost and 99.5 defuel at 22. I guess thats why mine throws the SES light so soon, and starts chug-a-lugging. Didnt know that there was a defueling difference in the early to late model trucks...
Nick
"The Mistress"
post #5 of 18 Old 11-22-2007, 06:49 PM
PSDfan99's Avatar
to be completely honest, I was setting my SES light every day from what I thought was overboosting, but I never felt the truck de-fuel. The SES light would come on and I would typically see no change in power or speed. I built my own boost fooler and set it for 20psi and my SES light doesn't come on at all anymore, but even when it did come on I couldnt tell it was de-fueling. But I must say, its nice not seeing that stupid yellow light every day.
Early 99 F-350
4" lift on 33's
Tymar Intake, Isspro Gauges, Modded IDM, HPX, Boost Fooler, 4" Exhaust
-BTS Tranny
-76mm Sledgehammer
-Swamps Tuning
-230cc Casserly Hybrids
-T.E. Modded 17* HPOP
-ARP's, Chromoly's, 910's
-ITP RR
-Jake
PSDfan99 is offline
post #6 of 18 Old 11-22-2007, 08:21 PM
your WOT lag is probably your HPOP not keeping up.....thats also the cause of the P1211....
mschn99 is offline
post #7 of 18 Old 11-22-2007, 08:24 PM Thread Starter
Doesn't Even Care
Quoted: 69 Post(s)
so does that mean my HPOP is bad? low on oil? whats my fix Marc?
Nick
"The Mistress"
post #8 of 18 Old 11-22-2007, 08:26 PM
it doesnt necicarely mean its bad....just might not be able to keep up with the demand of the chip like it once could under WOT.....and over a long period of time it will very slowely get worse. I would of course want to verify this with a scan tool to make sure thats what you have going on though. If it was found to be that, you could live with it or put a new pump, or twin pumps on to fix it...it would kind of be your call...
mschn99 is offline
post #9 of 18 Old 11-22-2007, 08:34 PM
What was the code being thrown lately? I totally missed the 1211 in your first post. But that was then. How long ago and is it the same that is being thrown now.
You can also call Tony and he cas set your chip to request less ICP and the will stop the light as well.
post #10 of 18 Old 11-22-2007, 08:48 PM Thread Starter
Doesn't Even Care
Quoted: 69 Post(s)
I have to have the truck scanned again to know for sure. I will write them all down, and get back to you.
On the HPOP thing, what kind of test do I need to have run on it? For future reference, how hard are they to replace? or to add a second one? what kind of price will I have to look forward to?
Nick
"The Mistress"
