anybody know???????????? - Ford Powerstroke Diesel Forum
post #1 of 17 Old 11-21-2007, 12:48 PM Thread Starter
F-350MAN's Avatar
I started my truck this morning and the weather is a bit colder out here in AZ than so cal about 30 degs last night. When I was warming it up this morning I noticed a leak thought it was oil but no, and it was dripping while it was running when i checked it, it was diesel (clean,clear & smelled like oil). Anyway I started looking and theres a tube above my lower alternator(01 7.3 w/two alternators) the drip was coming from there anybody know what this tube is or why it would leak? Its never done this before..thanks...
2001 F-350 CC LONG BED
SuperChips Micro Tuner
10k mod
4"turbo back silverline W/muffler delete
DIY tymar
ZooDad
ccv mod
Foil Delete
6'' Fabtech 2wd lift,on 325/70/18's open country
FORD MAKES IT
INTERNATIONAL
SHAKES IT !!
F-350MAN is offline
post #2 of 17 Old 11-21-2007, 12:55 PM
Powerstroke Techie
djsdiesel's Avatar
It is coming from the fuel drain valve on the filter houing, either go to ford and buy a new one, or somebody sells just the o-rings. Do a google search on fuel drain valve orings.
99.5 F-250 PSD AT 4x4, 4in lift, 37 13.5 18 Pro comp Extreme A/T's, S&B Intake, GTP38R, DP Tuner custom programs (140 Agg., 120 sled pull, 80 tow and 60 tow), Rosewood DIY stage 2 injectors, BTS Trans, 5in exhaust no muffler, 6 oh intercooler, Ford AIC, EBPV delete, Foil delete, T/C lock up mod, Pusher Fuel Pump, Three Chime train Horns
djsdiesel is offline
post #3 of 17 Old 11-21-2007, 01:05 PM Thread Starter
F-350MAN's Avatar
thanks buddy, where are the o-rings are they in the drain valve?
10k mod
DIY tymar
ZooDad
ccv mod
Foil Delete
FORD MAKES IT
INTERNATIONAL
SHAKES IT !!
F-350MAN is offline
post #4 of 17 Old 11-21-2007, 01:14 PM
Powerstroke Techie
djsdiesel's Avatar
There are 2- orings, behind the drain valve. Remove the 4 torx screws and the orings. If you have a hydraulic shopclose by take the o-rings there and get some 90 durometer orings to replace them or do a search somewhere it says what size they are. I'll look to and post if I find it.
post #5 of 17 Old 11-21-2007, 01:18 PM
Powerstroke Techie
djsdiesel's Avatar
1/8" thick x1/4" ID x1/2" OD
post #6 of 17 Old 11-21-2007, 01:22 PM Thread Starter
F-350MAN's Avatar
cool....I appreciate it, sounds like a quick fix.what about draining the bowl first? I've never done this
10k mod
DIY tymar
ZooDad
ccv mod
Foil Delete
FORD MAKES IT
INTERNATIONAL
SHAKES IT !!
F-350MAN is offline
post #7 of 17 Old 11-21-2007, 01:46 PM
John Wood Nut Swinger
strokin_early_99's Avatar
#90 O ring from your local ACE hardware store.
(Born on 11-20-98) F350 CC LWB 4X4
north of 480hp and south of 13.7sec
Bored with current setup
Family of 5 saved by Grace.....
Sponsored by Left Coast Diesel in Concord, Ca
Anything BUT Conservative Performance
strokin_early_99 is offline
post #8 of 17 Old 11-21-2007, 02:51 PM Thread Starter
F-350MAN's Avatar
does it need to be a special material (neproseen) or is rubber o.k.
10k mod
DIY tymar
ZooDad
ccv mod
Foil Delete
FORD MAKES IT
INTERNATIONAL
SHAKES IT !!
F-350MAN is offline
post #9 of 17 Old 11-21-2007, 03:12 PM Thread Starter
F-350MAN's Avatar
gonna run up there right now thank you...
10k mod
DIY tymar
ZooDad
ccv mod
Foil Delete
FORD MAKES IT
INTERNATIONAL
SHAKES IT !!
F-350MAN is offline
post #10 of 17 Old 11-21-2007, 03:22 PM
Desert Shield/Storm Vet
vitalidle's Avatar
Here ya go a good writeup Separator Valve Rebuild
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
