Different Year Engine Swap Question - Ford Powerstroke Diesel Forum
post #1 of 12 Old 11-20-2007, 03:14 PM Thread Starter
ne_plus_ultra_1's Avatar
I Have a 1997 F-350 7.3L, found a 2000 7.3L engine to put in my truck, maybe.
What do I have to do for it to work?
What fits and doesn't fit?
Any help appreciated.
Best,
-ultra
ne_plus_ultra_1 is offline
post #2 of 12 Old 11-20-2007, 03:18 PM
rankroddin250's Avatar
Im thinking have to swap in all of the obs sensors, injectors and turbo heres a free for ya.
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
The People of a free country should not be scared of their government, the government should be scared of their people.
rankroddin250 is offline
post #3 of 12 Old 11-20-2007, 03:27 PM
BIG TRUCK, SMALL DRIVER
pipelayerjdh's Avatar
The major parts will interchange. The block and heads will work. The accessories will need to be used from your truck. Also, unless you want to do a lot of wire swapping and splicing, you need to reuse your injectors to work with the '97 computer. The exhaust manifolds, up pipes and turbo can be swapped to the newer engine, or with a few modifications, you can use the newer turbo and parts. If you don't have an intercooler, you will have to use the old intake "Y". The old style mechanical fuel pump will have to be reused and the fuel bowl and lines from the old engine will have to be reused. In short, use the block and heads from the new engine and swap everything else off of the old one. The old oil pan will probably need to be used also.
Derrick
'97 F-350 "FORDOR" 4X4 (Dually Conversion, Shackle Reversal, Technicooler , Auto Meter Gauges, 4" DIY Dual Exhaust w/ '08 tips,
, Wicked Wheel 2, 360 thrust bearing, Homemade E-fuel conversion, Wildman Chip,
) 230K and counting...
pipelayerjdh is offline
post #4 of 12 Old 11-20-2007, 04:43 PM Thread Starter
Well, that's quite thorough.
That's too bad that I have to reuse my injectors, these other ones are brand new. I had wondered about that. I might be able to get the new computer with the engine. I'll find out tomorrow. It might be a wiring nightmare to swap it over, I dunno... I'll look into the availability of the ECM tomorrow.
I'd like to do some performance stuff within reason and if I'm not mistaken the 2000 had more power output than the 1997. I'd hate to turn it completely back into a 1997 but it man be expensive not to eh?
post #5 of 12 Old 11-20-2007, 04:57 PM
you might talk to tony wildman (Twildman) and see if its posible for him to burn you a chip that will allow you to use the 2000 injectors with the 97 ecm. i dont know if thats posible but its worth looking into. annother option would be to get a do it your self enjector kit and build your self some stage1s
out of your old injectors before putting them into your new engine.
post #6 of 12 Old 11-20-2007, 05:24 PM Thread Starter
Neat, stuff I never heard of before.
I could sell the other new injectors and pay for the whole engine too.
DIY injector kit and stage one injectors sound like a very interesting thing.
I take it that Twildman is on here. I'll look later. I have heard that the newer injectors are bigger, that's the only data I have on the difference.
Time to go sit down with the wife.
Best,
-ultra
post #7 of 12 Old 11-20-2007, 07:38 PM
bryanbrown's Avatar
wildman's website:
www.totaldieselperformance.com
'01 F350 2wd Lariat Dually 7.3 6sp-back to stock
'06 Dodge 4wd Dually, Auto, Edge Juice, AFE Bladerunner, 5" turbo back, BHAF
****SELLING ALL MY STUFF**NEARLY ALL GONE**PM IF INTERESTED IN ANYTHING***
Spearco 6.0 Retrofit I.C.- $800 shipped
coated uppipes(not bellowed)- $200 shipped
bryanbrown is offline
post #8 of 12 Old 11-20-2007, 07:40 PM
Best,
-ultra
I think the obs injectors are 90cc the early 99 are 120cc and the 2000+ are 130cc and the diy stage ones are 160cc. im sure some one will corect me if im wrong but thats what they are if my memory serves me corectly. if you go with stage1's your going to want custom tuning to get the most out of them any ways and tony is the man when it comes to the Obs trucks
post #9 of 12 Old 11-20-2007, 08:54 PM
John Wood Nut Swinger
strokin_early_99's Avatar
A and AA injectors came in the '94-'97 non-california trucks. They are all 90cc injectors and are single shots.
AB injectors came in the '97 cali, and all early '99 trucks. They are split shot injectors meaning they fire a small pilot shot before the main shot. These injectors flow 120-125cc of fuel.
AD injectors are also split shot but flow 135-140cc of fuel due to a slightly longer plunger stroke. These are found in all late '99-'03 Powerstrokes and T444Es.
(Born on 11-20-98) F350 CC LWB 4X4
north of 480hp and south of 13.7sec
Bored with current setup
Family of 5 saved by Grace.....
Sponsored by Left Coast Diesel in Concord, Ca
Anything BUT Conservative Performance
strokin_early_99 is offline
post #10 of 12 Old 11-20-2007, 08:57 PM
Best,
-ultra
Cali 97?
If so, your OBS PCM will work fine on the 2000 engine. The injectors are splits on both.
Do you have a intercooler on your 97?
If so the turbo system from the 2000 will work fine. Most of the other sensors will have to be swapped to work with the old style PCM.
