does the Ball Bearing turbo upgrade spool faster then 6.0? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-19-2007, 07:26 PM Thread Starter
Does the 88mm garrett or turbonetics dual ball bearing turbo upgrade for the 7.3 spool up faster then the stock turbo on a 6.0? I know those spool pretty quick because the variable vanes...
Thanks
makaveli200369 is offline
post #2 of 6 Old 11-19-2007, 10:23 PM
willypscustoms's Avatar
bump for some help
IF CAPS ARE ON IM AT WORK I CANT TAKE THEM OFF
willypscustom cold air intake
4" exhaust straight piped
banks 6 gun
itp regulated return
dp tuner
9" lift 37" tires
agr hydro. assist steering
greddy turbo timer and greddy gauges
wicked wheel
and some other small mods
willypscustoms is offline
post #3 of 6 Old 11-20-2007, 05:27 AM
Thats Mr. Oil Leak.....
MrJohnWayne's Avatar
Quoted: 5 Post(s)
mine spools fast. I have the Turbonetics. I'm not sure how quickly a 6.0 spools but I know the TN over stock 7.3 is a night and day difference!
John Wayne
Owner and Operator of the
REDNECK VALDEZ
You can find me on
MrJohnWayne is offline
post #4 of 6 Old 11-20-2007, 07:17 PM
lilredpowerstroke's Avatar
Why do you ask? Are you thinking of putting a 6.0 turbo on a 7.3??
T.J.
2003 F-350 dually 6.0
Centennial Edition
Straight exhaust 34x10.50 Swampers on Black Rock Stars
Been a member longer than most of the moderators
Thats why I said most Tiff
Think you can trust the government? Ask an American Indian!
My old truck in action
lilredpowerstroke is offline
post #5 of 6 Old 11-22-2007, 07:58 AM Thread Starter
No I just heard a 6.0 spool up the other day and it was pretty much instant. I'm wondering if I'll get the same performance out of a dual ball bearing with all the supporting mods.
post #6 of 6 Old 11-22-2007, 08:44 AM
ST PowerKore's Avatar
THe ball bearing and the variable geometry turbo are 2 different animals with the same purpose. The ball's a/r is fixed so it can only operate under one presssure input that is fixed with the wastegate. The variable can change it's a/r ratio infinitely between 2 set points. This gives it a huge advantage over the fixed turbo's. If you were to match up performance , it would be in the size of the compressor and it's wheel diameter. I believe the the ball has a slight advantage here, as i think the 6.0 turbo is a GT37 variant. The ball bearing works fine with stock injectors , and I believe, and you and ask others here, once you add the injects the Garrett wants to surge on you.
Mike
Air Flow Systems 5" Custom Intake
6" Air Flow Systems Side Exit Exhaust
DiabloSport Tow Tune
TS MP-8 Power Play
Edge Evolution As Gauge Monitor
FASS Fuel Pump 150 GPH
Snow Performance Stage 3 Water Injection
ST PowerKore is offline
