Installing billet thermo housing need help - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-21-2013, 04:40 PM Thread Starter
LEARNING AS I GO
bck4more's Avatar
Ok so i had ordered a new thermostat and housing from dieselsite and in the process of taking old one off one of the bolts was rusted bad and broke off. So i ended up putting new water pump on and i installed the new thermostat housing with new bolts but its leaking and im pretty gun shy about over tightening them so im wanting to use a torque wrench but dont know how tight im suppose to go on them. Any help guys?
1999 Ford F-250 Crew Cab Lariat 4x4 7.3L Powerstroke zf 6-speed Planet colors Amber White Pearl
banks big head wastegate, edge ez module
snow performance, 4" stright pipe,6637 FILTER MOD southbend stage 2 clutch, 05' front end upgrade
8" procomp 37" M16 Swampers 18x9 xd monsters, MOOG everything BILSTEIN SHOCKS BILSTEIN DUAL STEERING STABILIZER COOLANT FILTRATION, 203 stat 08' mirrors
bck4more is offline
post #2 of 6 Old 01-21-2013, 06:04 PM
Zaairman's Avatar
Quoted: 12 Post(s)
I torqued mine perfectly to specs and it still leaked a little. Put some RTV on it and tighten it up.
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust
, DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, Few leaves added here and there, 35" BFGs, 16x10 Eagle Alloys, Alpine W200
SLAPS Member #153
Zaairman is offline
post #3 of 6 Old 01-22-2013, 04:00 AM
kystanger's Avatar
I heard stories of the billet housing leaking so i put a bead of rtv on it the first time and it hasn't leaked a drop. The rtv seems to be the trick.
2008 f350 4x4 Stock
(SOLD)2001 f250 4x4
319,000 miles and counting.
6637 intake, 4 inch MBRP exhaust,gauges,203 degree therostat, leveling kit, transgo tugger kit, front and rear mag-hytec diff covers, more to come.
kystanger is offline
post #4 of 6 Old 01-22-2013, 04:12 AM
mxfever090's Avatar
Mine has leaked since installation. Just wet around the making surface. Nothing serious. When I get some free time I plan on using some RTV like others have mentioned.
Jason
O.T.F.D. Volunteer 19
Great White - 2003 7.3l F-250 4x4 CCSB -102,000 miles and tickin
DIY intake - 4" Straight pipe - HPX - CAT ELC - 203 t stat - billet t stat housing - coolant filter - dual alt radiator hose - 12V Air compressor - 5 gallon air tank - Air line quick connects - AIR HORNS!
Hers: 2013 VW Jetta TDI
mxfever090 is offline
post #5 of 6 Old 01-22-2013, 08:26 AM
rascal's Avatar
I had the same issue doing the same thing but I had the gasket beneath the thermostat.
Once I put the thermostat in the hole and the gasket between the thermostat and billet housing it no longer leaked.
Good luck!
Rascal
2000 F-350 XLT ECSB ZF6 4x4
38R+WW | Adrenaline HPOP | Optima | Ravelco | Mag Hytecs | Dynatrac | EBC | Strictly Diesel | AFE | Magnaflow | ISSPRO | DieselSite
rascal is offline
post #6 of 6 Old 01-22-2013, 09:31 AM
I had the leak as well and solved it with some black RTV. I really didn't want to have to add the RTV and hoped I would be one of the lucky ones that didn't need it, but I wasn't!
2000 F350 4X4 CCSB w/ 7.3 and 4R100
PIS 175/80, Adrenaline HPOP, 4" Exhaust, 6637 Filter, CCV Mod, Leveled Front, 315/75/16 Goodyear Duratracs
Devil Car is offline
