Exhaust leak - Ford Powerstroke Diesel Forum
Old 11-19-2007, 04:53 PM
Exhaust leak
Ok so i have my trans out and found out that my exhaust up pipe from the pass side has been leaking. My question is, Is there a gasket in there and what is the best way to service this issue?
Old 11-19-2007, 06:33 PM
there is a gasket in the upper connection you can replace it but it is bet to replace the complete pipe and gasket because the pipe gets a groove wore around it from viberations
and will leak again. i did mine and the pipes and gaskets from ford are only like 50.00 each side
Old 11-19-2007, 06:35 PM
yes there is a donut in there you can get them at any ford dealer or someone will chime in soon and give you the chevy part number for a little better seal
Old 11-19-2007, 06:37 PM
how long did the job take and was it a pain in the a$$
Old 11-19-2007, 06:40 PM
it took me the best part of the day i pulled my turbo and got the top one s that way and up from the bottom for the lowers
Old 11-19-2007, 06:47 PM
Cool I will call the ford dealer first thing in the morning and buy both of these pipes as I am already there.
Old 11-19-2007, 06:48 PM
but is it a dreeded job or enjoyable day under the hood
Old 11-19-2007, 07:43 PM
John Wood Nut Swinger
The ford donuts will luckily seal when new. The two best ones are car quest #17250 and the brass ones from Beans. The ones from car quest are $3 each and are the ones the Bean recommends. Bean also just released a set of brass donuts that are guaranteed to seal and not to blow out. He wants $89 for the new brass donuts.
No matter which way you cut it, the ford ones for $12 each have a habit of leaking. To me it is just not worth it. I have used the #17250 a few times but I will get the ones from Bean next time.
Keep Strokin'
Old 11-19-2007, 09:14 PM
International also has a fix for the leaking uppipes. They have built in bellows so you dont have to worry about donut gaskets anymore.
Old 11-20-2007, 09:06 AM
if the tranny is out is makes the install way easy. otherwise it is a couple hours of cussing... I had teh bellowed pipes installed.. if anyone needs some stockers just pay shipping.
