Old 11-17-2007, 11:47 PM
Stroked Stroked is offline
strong fuel smell
occasionally, now actually more often that not i have a strong fuel smell in the cab of the truck, and you can smell it outside too, what do you think? figure ill replace the o ring on the fuel filter canister the next thing around, but i dont see any fuel leaking anywhere, any thoughts?
Old 11-18-2007, 03:47 AM
NCHornet NCHornet is offline
Powerstroke Techie
Check the valley for fuel, not with a lighter!!! lol, The O ring on the fuel/water seperator could be a source, they started leaking shortly after the ULSD arrived. Have you changed your FF lately, sometimes the lid doesn't seal properly and will just let out a mist like stream of fuel under pressure so you may not see a gusher. A mirror on a stick and a flashlight is your friend when looking for something like this.
Good Luck
