Turbo removal
Do I have to remove the intake spider, or can I pull the turbo out sideways?
Sent from my iPhone using AutoGuide.com Free App |
I had to pull the intake and it still barely came out and I almost cut the valve cover wires when I did mine.
And whoever thought it was funny to torque the turbo bolts down to 500 ft lbs should be kicked in the nads. |
ya you gotta pull the intake spyder out.
it was probably heat and time that torqued your bolts down haha i felt the same way when i had to pull my turbo to do up pipes. i put some anti seize on the bolts so when i need to pull the trubo again it will come out . |
Pull the intake spyder, remove the turbo hold down bolts, twist the turbo a little, and pull it right out. It is not very hard to do at all.
