Stealth 1.1 HPOP - Ford Powerstroke Diesel Forum
Old 01-17-2013, 11:28 PM
Stealth 1.1 HPOP
I know it's been talked about before but I was looking to bring it up again and get some thoughts. I am contemplating buying a pump this year just for some more fun for the truck. Plus my truck spits and sputters when in WOT on the hottest tunes. I'm assuming it is b/c I'm still using the stock HPOP with Stage 2 singles.
I'm thinking the Stealth is a much better pump vs the adrenaline but was also looking at possibly doing a dual stock pump setup also. Not sure what others have done with similar setups to mine which is why I would like as much input as I can get before I purchase anything.
thanks
Old 01-18-2013, 01:23 PM
The Screwy HEUI
thanks
Quick question before I go any further: Do you have a boost fooler? It might be defueling from going over MAP sensor's threshold. As far as Stealth, they're a GREAT company. I'd definitely look into them. Someone might have some better insight.
Old 01-18-2013, 01:28 PM
Yes .. i did the 4.7 diode years ago.
