Old 11-15-2007, 12:45 PM
dieseldan2005 dieseldan2005 is offline
If it aint a CAT itsa DOG
coolant test strip probs??
I just got some of the fleetguard coolant test strips and did everything they said to do for the test, but the colors on mine won't change. So i added a bottle of the additive anyway cause i wasn't sure when it was done last, but shouldn't the nitrate and the other one change color to show where there at on the chart?
Old 11-15-2007, 02:24 PM
anybody know how to make these things work right?
Old 11-15-2007, 03:05 PM
ah anyone ??? bump bump
Old 11-15-2007, 03:18 PM
Lord Tauk Lord Tauk is offline
Send a message via ICQ to Lord Tauk Send a message via AIM to Lord Tauk
I dunno, I just dip it in, pull it out and they change. you're supposed to take the reading within 45 seconds of getting the pads wet I think recalling the directions in my mind.. not sure if the coolant has to be hot or cold.
Old 11-15-2007, 03:27 PM
yeah i tried it 2 times and the same results both times. No color change. Did you take the coolant from the regular tank or did you drain some from the rad pet****?
Old 11-15-2007, 03:43 PM
Just from the overflow res.
That's really weird, you're positive it's all getting wet?
Old 11-15-2007, 03:44 PM
D-man D-man is offline
I've heard these things go bad after a year. Could you have gotten some old ones? I always drain a few ounces from the radiator drain pet****.
Read it within a few seconds and I always double check the freeze protection with a Prestone antifreeze coolant tester. Since I completely trust the old style coolant tester, if the freeze protection doesn't match, I wouldn't trust the SCA or nitrate reading either.
Old 11-15-2007, 04:48 PM
NCHornet NCHornet is offline
Powerstroke Techie
See my reply to your other post on the same problem.
Old 11-15-2007, 04:55 PM
yeah, was that stuff you were talkin about, coolant or an additive?
