- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
Early 99' Powerstroke Fuel Leak
I started my truck this morning before I ate breakfast to let it warm up a little bit, and walked out to go to work and saw a puddle under the truck and a constant drip coming off the back of the engine. I had to go to work, but I did open the hood and check the valve behind the fuel filter. I got to work and asked permission to use the shop after work, and got to talking to a mechanic up here, and went to show him the leak. When I got out to the truck, I just turned the key on and pressurized the fuel system, and did not see the same leak as I did this morning. I will be jumping into this tonight after I get off work, and wanted to pick everyones brain as to where I should look. Thank you in advance for all the help.
| Sponsored Links |
My early 99 needed a fuel line replaced about 3 years ago. Pull the plastic cover off the top of the motor and check the one fuel line that runs across the top area. Mine had a friction wear hole from prior improper routing, etc...Re-built a fresh line at a friend's house in the boonies, where I was deer hunting, out of brake line with all the proper tools for making such a line. Has held up ever since. |
I have had these O rings in my truck for the last 3 years. No leaks.
| Sponsored Links |
