Old 11-15-2007, 05:47 AM
Sarasota Sarasota is offline
Transmission Filter - When to replace?
My 02 excursion has 60k miles on it and has never been used for towing - I'm going to be replacing the tranny fluid here shortly and wondered if the filter needs to be replaced or not.
Old 11-15-2007, 06:10 AM
bigcountrysg bigcountrysg is offline
duct tape & zip ties
You should replace the fluid and filter every 30,000 miles. You should also do a trans flush prior to a filter and fluid change.
