I have an idea for a security device but i suck at wiring - Ford Powerstroke Diesel Forum
post #1 of 16 Old 01-15-2013, 08:46 PM Thread Starter
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Ok so after reading several recent post about peoples trucks being stolen i came up with an idea that might help prevent that without spending several hundreds on a security system. but i know little to nothing about electrical systems. But my very neanderthal understanding i thought if there is some way to hook up the wiring for the starter to go into a switch mounted somewhere up under the dash hidden from view that i could switch off when i shut off the truck and back on when i want to start the truck.
That being said now its up to you guys to tell me im stupid and thats ridiculous, its ok i get it all the time
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #2 of 16 Old 01-15-2013, 09:29 PM
Term3's Avatar
Quoted: 2 Post(s)
A buddy of mine that has had his vehicles stolen twice in two years but could not afford to put in a car alarm so he wired up a LED flasher to the resr view mirror and made official looking window stickers that just said "WARNING This vehicle has a Cobra GPS theft recovery system installed". It's been three years now since he's lost a vehicle.
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #3 of 16 Old 01-15-2013, 09:31 PM
JoshF2Fiddy's Avatar
Good idea I have done this on my 65 impala but ran a switch hiden under the dash that when's its on I have coil power but when off there is no power going to the coil.
There is numerous ways to go about this,my suggestions are
Kill switch to fuel pump
Main ignition power kill switch
Battery kill switch etc
There are plenty of write ups that will show you step by step how too on google.
Good luck
Josh
01 F250 powerstroke crew cab
Rough country lift
XD wheels
All Terrians
Stock as a rock other wise
by
, on Flickr
JoshF2Fiddy is offline
post #4 of 16 Old 01-15-2013, 09:33 PM
Just wire in a switch in line with the electric fuel pump (lift pump). This will keep fuel from reaching the engine. Flip the switch and no power. Just use it as a ground interupt switch. Hmm, now I wonder. What if you have a DPDT switch that in 1 postion allows the truck to run normal, then flip it, and if your truck is trying to start, say it honks your horn. So, like you run it to the the fuel pump in postion 1, then when its flipped, and the circuit is activated, it will sound the horn as long as the truck is cranking. then, you wire your Big A$$ train horns into that circuit. I guess then you would have to worry about a cleaning bill for the seats. All though, you then would have a DNA sample...... """"heading to garage to see what wires I have laying around""""
None2Slow is offline
post #5 of 16 Old 01-15-2013, 09:38 PM
Term3's Avatar
Quoted: 2 Post(s)
I like the train horn idea but if I was the guy that ended up with bleeding ears and deaf I'd probably come back to the truck and set it on fire. LOL
Term3 is offline
post #6 of 16 Old 01-15-2013, 09:52 PM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Good luck
Josh
Hmm i didnt think about the fuel pump, the only reason i thought the starter is so when they turn it over it doesnt do anything rather than them cranking it and cranking until they gave up, thus wearing out my starter and batteries, and i didnt want a battery kill because then my pcm has to relearn fuel settings everytime and my radio will reset everytime and thats the most annoying thing in the world
Hmm that would be very interesting, if i wasnt wiring illiterate i might attempt something like that that would be like them turning on the alarm themselves
Well i dont have the full blown train horns but i have the wolo road warrior which is a little louder and more surprising than an oem horn which would be enough to scare the crap out of of the j-hole stealing my truck
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #7 of 16 Old 01-15-2013, 09:59 PM
mazsecond's Avatar
Feedback Score: 4 reviews
That would be bad azz!! I have to do this when I get train horns.
mazsecond is offline
post #8 of 16 Old 01-16-2013, 06:47 PM
7.3HeavyHauler's Avatar
pull the relay for the starter or fuel pump, painless and no wiring necessary, put it back in when you want to leave.
My avatar is my goal for the 7.3
7.3HeavyHauler is offline
post #9 of 16 Old 01-16-2013, 09:01 PM
If you do that, then you have to pop the hood and risk somebody watching you. Then they know that something under the hood was messed with and may figure it out. When you install a kill switch, dont just put it under the dash or the seat. Get creative. Most thieves have seen it before and know where to start looking. If they cant get it in a matter of a minute or so, there gone. A friend used a 4x4 activation switch on his lowered Chevy. They tried stealing it 3 seperate times and never got it. I think it did its job. Just to point out the obvious, it was a 2x4 truck
post #10 of 16 Old 01-17-2013, 02:01 AM
I would consider a different place than under the dash, lets say someone gets into my truck first thing they are going to see are my 3 gauges that I installed in the dash, plus a switch and what appears to be another switch (rheostat for hi idle), they go to cranking and its not starting, they may start flipping switches and if it still doesn't start then they are either A. giving up or B. know you've been doing things to your truck...mmmm wonder if theres a switch under the dash??....bam, he gets it started and drives off. I'm sure there are quite a few variables in there but all I am suggesting is a different spot than under the dash
my security system is my glow plugs believe it or not.....i have 2 of 8 that work, takes about oh 20 minutes to get it started when its less than 30 deg...i would think a thief would have given up after 5 minutes.
