Old 11-14-2007, 07:46 AM
chopstx667 chopstx667 is offline
Send a message via AIM to chopstx667
I want stacks!!
But the toneau cover poses a problem. Has anyone every dont a stack system through one? Must be kind of wierd since the cover moves up so you would have to possibly cut it at an angle. Maybe i'll just forgo it and get a set of train horns instead?
Old 11-14-2007, 08:01 AM
Marty Marty is offline
International Threat
Send a message via AIM to Marty
cut the cover ECHO did this...
Old 11-14-2007, 08:02 AM
haha but what about when I have to open it up? Mine is the one with hydraulics that go up.
Old 11-14-2007, 08:42 AM
REDPOWERSMOKER REDPOWERSMOKER is online now
WE ARE DOOMED
Send a message via AIM to REDPOWERSMOKER Send a message via Yahoo to REDPOWERSMOKER
cut a oval where the stacks will go through and then weld a piece of flat metal ( diamond plate looks great) onto the stacks where the hole is cut and put some GOOD sealer of some sort a good rubber strip will work if its a little ways away from the stack.. make it so that when you close it the rubber piece places up under your bed cover and seals it from the rain ive done this on a tool box never on a bed cap but its the same principal i would post pics but the truck i did it to was wrecked about three months ago and long gone
Old 11-14-2007, 08:30 PM
That sounds like a good idea. Do you think the rubber pieces would melt from heat if I ran too hot?
Old 11-14-2007, 08:33 PM
2005F250 2005F250 is offline
Do stacks outside the bed.
Old 11-14-2007, 08:37 PM
How would that work? I don't think I've seen that before
Old 11-14-2007, 09:02 PM
stacks outside the bed =
Old 11-14-2007, 09:13 PM
Logan Logan is offline
The Fat Mod
Old 11-14-2007, 09:19 PM
BOILERTURF2387 BOILERTURF2387 is offline
FORMERLY CHICKSDME2
Send a message via AIM to BOILERTURF2387
