Old 11-13-2007, 07:13 PM
sgleshot sgleshot is offline
Turbo leaking
Ok, I threw up a post a week or two ago about only being able to pull 12 lbs of boost from my early 99 7.3 psd. Well tonight I got a wild hair and thought that the little plastic tube for the boost gauge might be bent, kinked, or broken, So I replaced it with copper line like one would use for an oil pressure gauge on a hot rod. I noticed that the new line made the gauge operate much smoother than the plastic line. But upon routing the line I noticed an alarmingly large amount of soot inbetween the two sides of my turbo, give me all your input and tell me what ya think, how do I fix it?
Old 11-13-2007, 08:48 PM
strokin_early_99 strokin_early_99 is offline
John Wood Nut Swinger
Up pipe are leaking. Try to give the bolts at the baby butt a turn or two first. If they don't move don't force it unless you have time to drill out a broken bolt or two. If they need replacing I would use Car Quest part #17250. They seem to work the best.
Keep Strokin
Old 11-13-2007, 08:52 PM
I'll have to post pics at the office tomorrow, I plan on replacing my up pipes, but where its leaking is where the exhaust side of the turbo mounts to the centersection of the turbo. Its hard to explain without pics, I'll post them tomorrow mornin.
Old 11-14-2007, 09:33 AM
here's the pics.
Old 11-14-2007, 11:31 AM
dude, it looks like the top bolts are gone. Pull it before you damage the turbine wheel and inspect it!
Old 11-14-2007, 11:44 AM
now that you say that it does look like that, should there be heads for the bolts there? where do I get new gaskets and bolts and what not?
Old 11-14-2007, 12:08 PM
Marty Marty is offline
International Threat
This is the best one to look at...
Old 11-14-2007, 12:10 PM
CSIPSD CSIPSD is offline
That was a very common problem for the 99 trucks, the bolts would slowly work out of the exhaust housing causing that... Dennis at ITP diesel sells a bolt kit with wires to keep it from happening again... Or you can Locktite them and hope for the best!
Old 11-14-2007, 12:17 PM
so can I just pull the turbo when I re-do my exhaust, put new gasket in there and some new seals while i'm at it, new bolts, smasher home and be done with it?
Old 11-14-2007, 12:21 PM
Should just need the bolts... might not need to pull the turbo since they worked themselves out while the turbo was in there! I'd say get the bolts from Dennis and locktite them things!
