  #11 (permalink)
Old 11-14-2007, 12:26 PM
CSIPSD CSIPSD is offline
No gasket there, just get some new bolts and drive it home... A little locktite and you should be good!
  #12 (permalink)
sgleshot sgleshot is offline
would I need to put a new gasket in there? it looks like was pushin some soot from between the two flanges, is there even a gasket in there?
  #13 (permalink)
Old 11-14-2007, 12:31 PM
There is no gasket there, its a press seal...
  #14 (permalink)
Old 11-14-2007, 12:39 PM
gotcha I think I'm gunna pick up some bolts from the local fastenal, anyone know what size? Thread? Length?
  #15 (permalink)
Old 11-14-2007, 12:43 PM
This is probably a dumb question judging by the amount of soot all over in there, but to those holes that the bolts to to make it all the way into the turbine housing? if so that would mean it would be bellowing exhaust outta there all the time correct? Now with 2 of them bolts missing, I'm almost thinking that that might help out with my low boost issue. or am I outta my mind?
  #16 (permalink)
Old 11-14-2007, 12:59 PM
Marty Marty is offline
International Threat
It could be a boost issue for sure.
Get the right bolts and do it right...
  #17 (permalink)
Old 11-14-2007, 02:23 PM
strokin_early_99 strokin_early_99 is offline
John Wood Nut Swinger
it is releasing all your drive pressure that is needed to spin the turbo. I would pull the turbo to work on it and inspect it at the same time. But I'm anal retentive....
  #18 (permalink)
Old 11-14-2007, 02:36 PM
Originally Posted by strokin_early_99 View Post
it is releasing all your backpressure that is needed to spin the turbo. I would pull the turbo to work on it and inspect it at the same time. But I'm anal retentive....
Drive pressure... but I'm not correcting you... LOL
  #19 (permalink)
Old 11-14-2007, 04:43 PM
Corrected just for you sweet heart!
  #20 (permalink)
Old 11-14-2007, 08:41 PM
well, as nuts as it seams, does anyone know what size? and length the bolts are? I just want to get something in there before I get that lock kit, I want it fixed wether it be temporary or not. anyone?
