Help!!!
So I thought I was going crazy but nope I'm not, truck is a 01 f250 4x4 ext cab 7.3.....now I'm not familiar with this, but the passenger front tire is closer to the bumper then to the back of the tire well, and the driver side is closer to the back but a bigger gap between tire and bumper....any ideas?
Modified suspension?
Front differential shifted on the leaf springs?
I have noticed the same thing only reversed on my red truck... right tire rubs often while the left rairly does.
After getting new tires recently and the rubbing being worse due to larger tires I am concidering losening the U bolts on the side that rubs and trying to move it as far as the center pun will alow... the center pin often have a little slop between the springs and axle which might make a diffrence in my case. How much difrence is there from side to side on yours? If it is noticeable Im guessing it is a quarter inch or more... Sent from my SCH-I200 using AutoGuide.Com Free App |
Could the front bumper be hanging lower on one side than the other causing it to look like the tire is moved forward and isn't?
Great point. Ive seen this before.
Thank y'all for the responses, it has a leveling kit, I did think the bumper could be hanging however passenger side rubs when I turn too hard....Driver side never rubs
Would this also cause the truck to look weird from the back? Like looking at it from behind I see the top of the bed rail on the drivers side but not on te passenger side, however after I measured the space between the bed and window seal (up front where bed meets the cab) it's the same on both parts....and would this make my front end squeel when I'm turning at very low speed? Really appreciate it y'all
That wouldn't have anything to do with the alignment of the front end but I can see in your avi that your bed possibly looks a little tweeked towards the passenger rear. Post up some pictures so we can see better as to what you're referencing.
Make sure too that you're parked on absolutely as level of ground as possible when looking/taking pictures. |
I took the pictures, but don't know how to upload them :/ my apologies
