Oil pressure - Ford Powerstroke Diesel Forum
Old 01-13-2013, 04:47 PM
Oil pressure
I'm haven't had any problems all day came out started it it comes up low on the gauge with a light then goes up to the has way in about 2 or three mins and.turns off any ideas? I have been having a leak from the drain plug
2000 f250 7.3 ts 6 pos straight piped 6 speed
Old 01-14-2013, 06:04 PM
Have you checked your oil level?
Old 01-14-2013, 08:41 PM
yeah i was 2qts low filler up and was good... i have a slow leak at the drainbolt gasket thank you!
Old 01-15-2013, 08:07 AM
it was about 26 degrees this morning started my truck took forever to get oil pressure never noticed that before shut it off started again fine any ideas?
Old 01-15-2013, 10:26 AM
Have you tried replacing the oil pressure switch?
Old 01-15-2013, 10:32 AM
No I haven't just got thus truck where is it located and how much is a new one?
Old 01-15-2013, 02:56 PM
It is on the HPOP reservoir. They are around $20.
