Old 11-12-2007, 09:20 AM
CUMMINS_KILLA99 CUMMINS_KILLA99 is offline
will they fit
hears what i want to do. i want to get 36X14X16 in. ground hawg radials mounted on m/t classic wheels 16x10. i want to know if they will fit with only a 4in. lift i had 35s with no lift but on stock rims and theres guys on here that clear 37s with a 4in. i want to keep it low so i can still pull a goose neck. has any one on here ran these tires i heard they wear extremely well for what they are. what do you guys think
Old 11-12-2007, 09:21 AM
i forgot to add i dont mind minor trimming i just dont want to tear up the sheet metal
Old 11-12-2007, 09:26 AM
07OUTLAW 07OUTLAW is offline
Never been banned!!!:)
Don't know if they'll fit. But Ground Hawgs are AWESOME tires . I had a set in 42" on a Ford gasser (i didn't know any better at the time)about 8 years ago. I loved the tires, though I'd never go so big again. Great off road, good on road and they wore pretty good for what they were (as you said).
Old 11-12-2007, 12:50 PM
anybody have an opinion
Old 11-12-2007, 12:55 PM
Pullinpower7.3 Pullinpower7.3 is offline
M4 in my tool box
With the correct backspacing you can run them with minor trimming. I stuffed 39.5 swampers under my truck with a 3.5" lift and only rubbed at full lock(turning left) and my drivers side at full stuff in the mud hole. the wheels only had 3.25" BS but you could maybe get by with a 4" BS. the 14" width is where you will have trouble, not the height
Old 11-12-2007, 12:58 PM
CSIPSD CSIPSD is offline
I run 37" Toyo MT's combo works great for me! It takes a bit of work on the rim offsets, and I cant recall what mine are now... The thing thats going to kill you is the width of those tires... Toyos are only 13.5" wide, your looking at a 14"... Mine rub on the springs at full lock, yours will RUB HARD at full lock...
Old 11-12-2007, 12:59 PM
lifewitlooie lifewitlooie is offline
COLLEGE KID
Send a message via AIM to lifewitlooie
i dunnow... its a tight fit.. put the lift on first and see what happens
Old 11-12-2007, 01:09 PM
i tryed my buddies tires on my truck with my 2 1/2 in. leveling kit his tires are 35 in bfg muds on 16.5X12 weld typhoons and they hit th bumper slightly and the fender slightly i figure with a 10in. wide rim and about 1 1/2 to 2in. more of lift they should fit beins that the tire will only be a inch taller
Old 11-12-2007, 01:13 PM
COLLEGE KID
honestly.. 36 might work. i wouldnt try anybigger though... why not go with 35'z then?
Width... MAN its the Width that will kill you, the wider they are the bigger ark they have when you turn, so they hit the bumper and rear of the front fender. The BFG's are only a 12.5 wide tire, and they really only mesure about 12...
