Help!! Rear Rotors Shot!! - Ford Powerstroke Diesel Forum
post #1 of 9 Old 11-11-2007, 04:04 PM Thread Starter
Hey folks! I'm replacing the pads on my 99.5 F-350 CC 7.7 dualie. I found my right rear rotor worn completely out. Since I have never removed a rear rotor before, does anybody have advice or a link to info. on proper procedure?
1999.5 F-350 7.3 CC DRW 4X4 LB B&W Fifth Wheel Fumoto
SuperStroke is offline
post #2 of 9 Old 11-11-2007, 06:13 PM
jcs
jcs's Avatar
here is what i know remove the wheels,caliper,caliper mounting bracket then take a big hammer and beat the rotor off from the back side but move around the whole thing not just in one place hope this helps
early 99 7.3 supercab xlt s/b auto 4x4
08 Tailgate
Isspro gauges (boost,pyro,trans temp)
Ford AIS
jcs is offline
post #3 of 9 Old 11-11-2007, 06:17 PM Thread Starter
Thanks JCS! Do I have to take off the axle and hub? Mine is a dual wheel.
post #4 of 9 Old 11-11-2007, 06:23 PM
jcs
jcs's Avatar
no you dont it just slides over
08 Tailgate
Ford AIS
jcs is offline
post #5 of 9 Old 11-11-2007, 06:26 PM
Send a message via MSN to bryan70546 Send a message via Yahoo to bryan70546
this might help you , I did mine today and it was very easy .hope it helps
Video - Brake Job lll
2004 6.0 4door SWB lariat BUILD DATE
09/05/2003
ZooDad Mod Custom seat covers .4" duels with 6" tips no kitty ,no muffler .Issapro Boost , Trans temp , pyro .S&B Intake . Accufab intake elbow.Tow Mirrors installed finally, EGR Delete
2008 Yamaha Bigbear 400 with ITP mudlites & ITP ss12s . 2007 Yamaha 700 FI Raptor LTE duels ,GYRT intake and filter Dobeck powercommander 2.
2008 Yamaha R6 Raven
bryan70546 is offline
post #6 of 9 Old 11-11-2007, 09:00 PM Thread Starter
Hey Bryan, Thanks for the link to the video! That helps alot!
post #7 of 9 Old 11-11-2007, 10:38 PM
any time brother
I have it saved on my computer , Like I said I did my rears brakes today following the steps on the video and it went very well . good luck and be carefull when you are around the the wheel wells on with that big ole duelly I used a big floor jack and jack stands.
09/05/2003
post #8 of 9 Old 11-12-2007, 05:48 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
Yes you do have to take the axle out. Its the smaller 8 bolts on the hub. Slide the axle out, and then you are gonna need a 3 pronged tool from Ford to take the hub bearings out. The you can remove the hub once you have the caliper and the bracket off. Flip the hub upside down and then remove the 15 bolts holding the rotor to the hub. wal lah! done.
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #9 of 9 Old 11-12-2007, 09:28 PM Thread Starter
Thanks for the heads up on that rear axle! I've just got to find the right socket for that bearing nut.
PS: That is one bad mustang you have there!!
I have a couple of older ones myself, both need restoring. 65 289 4spd, 70 Cobra Jet.
