where to lube my Superduty powerstroke? - Ford Powerstroke Diesel Forum
Old 11-10-2007, 04:46 PM
Hi Guys,
Mine is a 1999. Does anyone have a pic that shows where all the zerks are for a lube job? If so, post a link.
Thanks
Old 11-11-2007, 04:07 AM
Powerstroke Junkie
There are just four of them and they are very easy to find by crawling under the truck. Sorry I don't have pics.
Old 11-11-2007, 04:09 AM
Almostdunfukinwidit
Thats true unless his ball joints have been replaced
Old 11-11-2007, 04:11 AM
If the balljoints have been replaced there will 2 per side(factory non greasable) 1 on every tie rod end 4 total and if ujoints have been changed those will be servicable.
Old 11-11-2007, 04:49 AM
original ball joints
My truck has 23k on it and the ball joints are original. Are you saying that the aftermarket ball joints eliminate some of the grease fittings?
thanks
Old 11-11-2007, 04:55 AM
Almostdunfukinwidit
No aftermarket ones usually are greaseable. The stockers are not
Old 11-11-2007, 05:43 AM
Member/MARINE
Send a message via Yahoo to rajharley
Yep...Marc put on some new ball joints for me recently. Thanks Marc. The new ones have the grease zerts on them. If you only have 23k on your rig I would think that you have a bunch more miles before that will need changed. Good thing is that the ball joints are pretty cheap. The install is kida tricky though. Requires some special tools to make it easier. Marc had the right tools and he did it in a flash. Could have been faster if my amature compressor could have kept up with his professional tools.
