I am fairly new to the diesel market, so I have a few questons / comments.
I have a 2001 F350 4x4 crew cab 7.3L with 170,000 miles. It has a 4" turbo back MBRP exhaust, AFE stage 2 intake, and Edge Juice with Attitude monitor. I tow a 34ft 5th wheel which weighs around 14,000lbs. To say I have been dissapointed with my upgrades is probably an understatement. Specifically, my egt's are super high, no matter what setting the juice is set at. I will be at 700-900 degrees city driving on the freeway even at the stock setting. When I tow, I can only muster 45-50 mph @ 1275 degrees on a 6% grade. I have never gotten over 16lbs of boost. None of my upgrades improved mpg or egt's whatsoever, and I only noticed minor power improvements. Am I expecting too much? Are my egt's normal? What kind of boost should I be getting? Other than an aftermarket turbo or bigger intercooler, how can I lower my egt's? Any help would be much appreciated. Scott
Sounds like you might have a boost leak somewhere. I have custom tunes and I told my tuner about the EGT's being high and he fixed it for me. If it were my truck I would start checking all the intercooler boots to make sure they are tight and not leaking. I would also get rid of the Edge and get some custom tunes on a flip chip.
Thanks for the reply.
So where would I go to get custom tunes, and how much does it cost? What is normal boost for a 7.3L? |
Check out totaldieselperformance.com
or Dp Tuner DI Performance - Your Powerstroke, Duramax, Cummins Performance Headquarters Welcome to Elite Diesel Engineering These are all really good custom tuners |
