HID high beam problem - Ford Powerstroke Diesel Forum
Old 01-11-2013, 02:20 PM
Just installed a set of HIDs and te problem is that only the high beams are on. Even in the regular position my blue light is on on my dashboard. When I pull the lever back or push it forward on the steering console the blue light gets brighter but the headlights do nothing and remain the same. I am baffled. All connection are good and tight. Maybe sand the spot were I put the grounds but if it wasn't properly grounded would it even work???
Old 01-11-2013, 03:01 PM
Just sanded down te ground and still no change. I'm stumped.
Old 01-11-2013, 05:08 PM
My guess is the connector thing your normal headlight plug is plugged into is tripping it.
Old 01-11-2013, 05:16 PM
Love to hate me ;)
Ok, more than likely what Happened is where the hid kit plugs in to the factory harness the high/low beam wires are swapped... You will need to swap the wires around in the plug from the hid kit that goes to the factory bulbs
Old 01-11-2013, 05:23 PM
I'll try giving that a whirl tomorrow or maybe tonight cause I'm impatient haha. How would you recommend switching them, cutting them a few inches back and splicing them into the other one?
Old 01-11-2013, 05:58 PM
Love to hate me ;)
Ok if you look down into the plug on the hid harness that plugs into your factory headlight harness you will see the. 3 metal plugs you can use a small pick and push the clip that holds the wire and pull the whole wire out of the plug so there's no need to cut anything... Pull all 3 out and swap them around until you find the right way
Old 01-11-2013, 06:00 PM
Ok thank you. I'll report back when I try it out and let you know what happened!
Old 01-11-2013, 06:20 PM
Lowdown89 you are my hero haha. The wires originally went red white blue, swapped them around a few times to blue red white and it works as it should now! Thank you again!!!!
Old 01-11-2013, 06:26 PM
Illiana Chapter Director
I can't remember the colors but when I got mine from DDM you had to insert the wires for hi/low into their plug. Look at the directions and swap only the 2 wires that are for hi/low.
Old 01-11-2013, 06:46 PM
Directions are for sissies
