Randomly won't crank - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-11-2013, 09:31 AM Thread Starter
I've recently been having cranking issues with my 02 F250. So far, this is happened three times over the last few weeks. Batteries are great, alternator is new, so power shouldn't be the issue. I recently replaced the fuel separator valve and while under the hood I might have bent some wires. In order to get it cranked, I have to wiggle all the wires around the starter solenoid, as well as tap on the solenoid itself. Eventually, I get it to turnover.
My question is this: How do I isolate whether it's a specific wire leading to the solenoid, and test the solenoid with my meter?
I appreciate any info you could provide....still a newbie in tackling some of these issues, but thoroughly enjoy fixing it myself. This site is always my first stop, and extremely beneficial!!
Texas Ag is offline
post #2 of 3 Old 01-11-2013, 09:51 AM
Tj Krawler's Avatar
Mine was doing the same thing. About once a month it wouldn't crank. After a month or two, it did it twice in 1 week before I had to go on a 8 hour trip. New starter and relay. Don't really know what one it was, but it's been good since.
I would check the wires around the starter for corrosion and make sure they are tight.
When it's not starting, you would have to see if you have power at BOTH the big terminals on the relay. (the one bolted to the passenger side fender)
Or if you can't watch the meter and turn the key at the same time, you can put power across the 2 big terminals, if you KNOW power is getting through the relay and it still isn't cranking, problem is at the starter.
It could be related to the ignition switch or trans too. When you turn the key "on" and the lights come on, do they go back off/on when you turn the key to "start"? Ignition is fine if they do.
If you have an auto, when it doesn't crank, with the key on, foot on brake, hold the shift lever up into park, or try in neutral.
Alan
2000 F-350 CC LB DRW 4x4 XLT Auto
- Intake
- Exhust
- ScanGauge
Tj Krawler is offline
post #3 of 3 Old 01-11-2013, 11:56 AM
mine does it and its the shifter.if i move it all the way up in park or pull it down a little then she cranks.
adams01 is offline
