A beeping I have never heard before? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 11-08-2007, 02:05 PM Thread Starter
cchase's Avatar
Well I started up the rig this morning and as I was driving down the street i heard a Beep, Beep ........... Beep, Beep and I have never heard the tone before. So I stoped and looked over the dash and noticed that my airbag light was out, now this light has always been on for the year I have owned the truck. The beeping goes away after a couple minutes and only comes back on start up, any ideas on how to stop it and what it means?
On vacation from a truck for a year or...
Looking at 6.4s Moving in a few months then hopefully buying my dream truck!!!
Driving an Audi till then...
but at work I drive
16 E-450s 7.3 powerstroke Ambulances
7 Duramaxes
1 GMC Kodiak Ambulance
NO CUMMINS.....
cchase is offline
post #2 of 10 Old 11-08-2007, 02:49 PM
Action Rick's Avatar
It is telling you to replace the burned out air bag light bulb......
97 F350 4x4 Straight exaust ,performance injectors, 6 pos chip, 4" lift work truck
They say" most stuff is just stuck and need's hittin' with a hammer
Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX
Action Rick is offline
post #3 of 10 Old 11-08-2007, 03:12 PM Thread Starter
cchase's Avatar
nice, that means the light will stay gone, now I wonder how long it will take for the noise to burn out...
but at work I drive
7 Duramaxes
NO CUMMINS.....
cchase is offline
post #4 of 10 Old 11-08-2007, 05:23 PM
460+'s Avatar
Its just like a CEL have someone scan it and fined out what it says.If someone worked on the truck before they may have broke the airbag strap in steering column.
99 F350 4x4 dually
7.3 w/K&N af
4" exh into 6" Aussies stacks
4"lift &35" tires
CC mod HP crossover line
Beans stage II 120hp injectors
D66 turbo
ITP regulated return
reburn on TS= 25,high idle,60,100,120,140hp
updated ecm (2000 model)
Dyno#'s 360hp and 965 ft lbs trq
460+ is offline
post #5 of 10 Old 11-08-2007, 07:51 PM Thread Starter
cchase's Avatar
the beeping is more annoying than the light.... the only way to fix this is probably to fix the airbag? I dont really care about the air bag because I have always been under the impression that its expensive and to get it scaned at ford its 150 bucks..
but at work I drive
7 Duramaxes
NO CUMMINS.....
cchase is offline
post #6 of 10 Old 11-08-2007, 09:44 PM
sirnunya's Avatar
is there a fuse you can take out? did the airbag light used to stay on when you drove the truck?
sirnunya is offline
post #7 of 10 Old 11-09-2007, 11:21 AM Thread Starter
cchase's Avatar
yeah, idunno about fuse
but at work I drive
7 Duramaxes
NO CUMMINS.....
cchase is offline
post #8 of 10 Old 11-09-2007, 03:18 PM
When it was flashing , do you remember how it did it?..Like Flash Flash.......flash flash flash for 23 (as an example)
post #9 of 10 Old 02-08-2010, 09:31 PM
Flooringit's Avatar
Quoted: 27 Post(s)
I have that annoying beep comes on when I first get I'm truck them after driving I hear it once in awhile. But when I bought the truck column had issues mainly the shift tube was broke and so was shifter cable that's all fixed now but how do I figure out if the air bag strap is broke? Where is it what does it look like.
Flooringit is online now
post #10 of 10 Old 02-09-2010, 05:27 AM
More than likely it's the "clock spring" causing the airbag code, which in turn caused the airbag light, which in turn now that the bulb is burnt out causes the beeping.
It's about an $80 part, and not hard to replace. Just requires removing the airbag assembly to get access to it.
-Robert
'00 Ford F250 4x4 PSD
'89 Pontiac Turbo Trans Am
'03 BMW 530i Sport
Hi-psi is offline
