Tranny Fluid Change ??? - Ford Powerstroke Diesel Forum
post #1 of 29 Old 11-08-2007, 09:57 AM Thread Starter
cowgirliemoe's Avatar
Question Tranny Fluid Change ???
I don't know when the last time the tranny fluid was changed (truck is new to me). Its got almost 200k miles. I wanted to change it soon. Fluid recommendations? Cost? Any filters I should change? Tricks?
Any info would be great!
-Moe
2001 F250 diesel 4x4 Lariat
hauls the horses, racecars, dogs, friends, furniture, dump runs. . . .
mods-Weathertech floor mats--front and back now!!!!!
**some girls can drive**
cowgirliemoe is offline
post #2 of 29 Old 11-08-2007, 09:58 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
I would flush it with Amsoil ATF if it was me. But any DexronIII mercon will work
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #3 of 29 Old 11-08-2007, 10:16 AM
KVFD
redstroker_2002's Avatar
i would take it to a jiffy lube or something like that so they can change the filter (you have to take the whole pan off) and have them flush it. It takes almost an hour but its well worth it for them to do it
-Josh
2008 2500 LMM- Deleted, Blocked, Fueled, & Tuned by:
redstroker_2002 is offline
post #4 of 29 Old 11-08-2007, 10:21 AM Thread Starter
Ahhhh, exactly the info I wanted. So I'm assuming there's a gasket that will need to be replaced also?
-Moe
post #5 of 29 Old 11-08-2007, 10:59 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
if i remember right the gasket is reusable on our trucks
Email:
Edge Insight CTS
Coolant filter
Dave is offline
post #6 of 29 Old 11-08-2007, 11:00 AM
International Threat
Marty's Avatar
Gasket is reusable.
Do you plan to do it yourself or are you taking it somewhere?
2001 F250
11.62 @ 115.79
Owner of Marty's Diesel
Elkton, Maryland
Marty is offline
post #7 of 29 Old 11-08-2007, 11:02 AM
01PowestrokeDSL's Avatar
The gasket is reuseable. I did mine without jacking it up, it's really easy. Just a little messy. Just make sure you torque the bolts at 20 inch pounds, and make sure the seal for the filter comes out.
Not sure what kind of mechanical experience you have, but it was easy. Also, most people say if your tranny fluid has not been changed at 100,000mi then not to change it at all. I have never done this though. All of my vehicles get changed at 50K.
01PowestrokeDSL is offline
post #8 of 29 Old 11-08-2007, 11:07 AM
parrothead96's Avatar
I second the "you might not want to change it" thought. I just picked up a 95 PSD with 220k on it, it was shifting a little funny so I changed the fluid. Needless to say it didn't shift well after that. Cold it was OK, but once it warmed up it would not hit second.
I would say if it shifts fine and the fluid looks OK, maybe change it. If it shifts funny and the fluid is dark...you might want to think about it or take it to someone who knows transmissions really well and get their opinion.
parrothead96 is offline
post #9 of 29 Old 11-08-2007, 11:36 AM
Powerstroke Techie
alabamafrog's Avatar
I say change it and change it regularly, these things are very expensive to replace. I personally would not even consider taking it to a lube shop and having it flushed, too risky in my opinion. It is very easy to do, on mine I drained the pan and the converter (most trucks have a drain plug in the torque converter) and got 16-17 qts out of it. There is a filter in the pan that needs changed but it is easy too. If it were my truck I would go with Amsoil synthetic and add a Trucool 40,000# tranny cooler behind the front bumper and a temp gauge if it doesn’t already have one. Should cost less than $200 to do all that. Also the transfer case takes the same fluid and the rear end lube should be changed too.
“Government, even in its best state, is but a necessary evil; in its worst state, an intolerable one” (T Paine)
Government cannot give anyone anything without stealing it from someone else. (A Frog)
alabamafrog is offline
post #10 of 29 Old 11-08-2007, 11:38 AM
Marty's Avatar
The "don't change it if it hasn't been changed" is an old wives tale. Get the old fluid out and the new stuff in. The biggest problem is not properly filling the tranny and most of the time after the change you're LOOKING more intently for problems, so you find them.
2001 F250
11.62 @ 115.79
Elkton, Maryland
Marty is offline
