Tires!! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-05-2007, 08:51 PM Thread Starter
Tires!!
I need new tires before the snow flies. For those of you that tow and daily drive. What tire was the most stable and worked good all around. This is for a 99 SD 4x4. Just looking for a stock size but wider would look better. During the summer I tow my car trailer often and at most load weight is 6000-7000lbs. It had steelteks on it when I got it and when they where worn I replaced them with Cooper M+S . I got them because I liked the lug design and the supposed superior snow traction. However, the first time I hit the highway with my race car on the trailer I about shyt. Frigin tires are unstable as hell even cranked up to 85psi. Yep, they are E rated. Lots of side to side sway.
So I learned to live with it since I already had them. The steelteks drove straight with no sway . Just solid.
So give my your opinion/experience.
tbird is offline
post #2 of 6 Old 11-05-2007, 09:04 PM
sawyer1's Avatar
tires
put these on about 4,000 miles ago and love them. I also tow about 5,000 pounds and there real smooth.
Les Schwab Tire Centers - Winter Tires - Mud Terrain SXT
-Sawyer-
USAF COP!!
2000 F-250 Lariat, 142,000mi automatic trans.
SOLD SOLD
New rig 2006 dodge cummins mega cab
sawyer1 is offline
post #3 of 6 Old 11-05-2007, 09:11 PM
jostaman's Avatar
Smile nice pipe placement
that exhaust looks good
Jim in Chandler Arizona 2000 F-350 and yes it is "APG White" ,Cable Guy so any cable questions ask away. It is sorta stock now ,but thanks to
It is growing. AIS ,HPX , 4 inch exhaust . running AMSOIL fluids in everything. Got single oil bypass an Fumoto Oil Drain Valve got tuner now just not installed yet .
jostaman is offline
post #4 of 6 Old 11-05-2007, 09:13 PM
sawyer1's Avatar
thank's man
-Sawyer-
USAF COP!!
SOLD SOLD
sawyer1 is offline
post #5 of 6 Old 11-05-2007, 09:14 PM
Desert Shield/Storm Vet
vitalidle's Avatar
This is the best tire I ever bought for traction in the snow! They absolutely rock! However they are not E Rated. I tow my boat occasionally and its 5000 pounds without any adverse effects. I will buy them again
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
AIH Delete With Boost Fitting
vitalidle is offline
post #6 of 6 Old 11-05-2007, 09:17 PM
sawyer1's Avatar
I also had the mastercrafts on a bronco no complaints.
-Sawyer-
USAF COP!!
SOLD SOLD
sawyer1 is offline
