Level kit (not level) - Ford Powerstroke Diesel Forum
Old 11-05-2007, 05:18 PM
I installed level kit by skyjacker 2.5. after done check with a tape and the rear still about 1 1/2 higher in rear its a 00 f350. is something wrong with my kit?
Old 11-05-2007, 05:25 PM
You drive a 4x4 truck?
Old 11-05-2007, 05:28 PM
International Threat
Your F350 has a good size block in the rear - somewhere between 3 and 4 inches. So a 2.5" leveling kit will come up slightly short... but should give it a better stance.
Old 11-06-2007, 08:21 AM
you could put a shorter block in the rear if you want level. my buddy just put a leveling kit on his dodge 03 dually and it doesnt sit level either its normal
Old 11-06-2007, 08:27 AM
Let's Run'em
No there is nothing wrong with the kit....its just the way the truck looks, if that makes any sense....the suspension is level, but the way the body sits on the truck it will look the same (higher in the rear) but lifted.....to correct it I agree with the others, just switch out a different block so it looks level to the eye...
Old 11-06-2007, 08:32 AM
You can get a rear block from an F250 and swap it out. That should level you out.
