rim/tire size ??'s
Guys will rims off of a 05 and newer fit an 01 or an 04S.D.? My brother has a king ranch 04 with 18's and he's looking for some take off rim and tire combos to just mount up. Will the newer rims bolt right on or not. Also would they fit my 01? Thanks guys!
anyone have any ideas? Bump Bump
I'm pretty sure they won't fit your 01
NO! I just went thru this and our leaf spring front end trucks came with 4.5 inch backspaced wheels. The coil spring fron end trucks came with 5.5 inch backspacing. The problem is the 5.5 inch backspaced wheels will rub the leafs and it kinda looks dumb with wheels sitting in as they do. I was told not to try wheel spacers but me being very stubborn I bought a set anyway and that was a waste of time. They are not ballanced and now the wheels rub the mudguards. I am now selling the wheels and spacers because I bought a lift and 35's
Eric |
Is the bolt pattern more spread apart or what? For the longest time you could swap rims even with some dodges. Do you need to buy a different hub assembly?
bolt pattern is the same 8x170
oh ok, i replied before i read your post fullspeed, thanks for the info. Man that sucks, you would have thought that Ford would have made em so you could swap rims. Oh well.
