4" Exhaust - Ford Powerstroke Diesel Forum
post #1 of 9 Old 11-04-2007, 08:23 PM Thread Starter
4" Exhaust
Is it worth putting in a 4" Exhaust on a 2000 Excursion psd?
2000 Excursion 7.3 psd
80,000 Miles
PowerSlot Cryo Rotors + Hawk Pads
Edelbrock Performer IAS Shocks
Diamond Eye 4" Turbo back exhaust
DP Tuner F6 chip with 60HP tow, 80HP Econ and Decel Tunes
Boost, EGT and Trans Temp gauges on pillar
K&N air filter in stock system
Pull Rite towing system
6.0 Trans Cooler
redoil is offline
post #2 of 9 Old 11-04-2007, 08:23 PM
Raul@Stealth Automotive's Avatar
Yes..... and a better flowing intake too
Raul@Stealth Automotive is offline
post #3 of 9 Old 11-04-2007, 08:26 PM Thread Starter
I have a KN filter on the intake -- is that what you mean?
80,000 Miles
6.0 Trans Cooler
redoil is offline
post #4 of 9 Old 11-04-2007, 08:30 PM
oh.... i would def take out that K&N... they let in too much particles that can mess up the fins in the turbo.... they may let in more air but they also let in more dirt too..... i would switch to a AFE intake or the DIY intake...
post #5 of 9 Old 11-04-2007, 09:19 PM
John Wood Nut Swinger
strokin_early_99's Avatar
The K&N have a bad habit of not sealing and letting crap through damaging the very expensive air compressor you drive.
Exhaust will let the EGT's cool down a little so you can keep your foot into it more. However it has been said that with a stock truck the 4" down pipe will loose some of the low end spool up. Those folks say the 3.5" down pipe is the way to go. I do not have a stock truck so I can not answer it this is accurate.
(Born on 11-20-98) F350 CC LWB 4X4
north of 480hp and south of 13.7sec
Bored with current setup
Family of 5 saved by Grace.....
Sponsored by Left Coast Diesel in Concord, Ca
Anything BUT Conservative Performance
strokin_early_99 is offline
post #6 of 9 Old 11-04-2007, 09:42 PM
Addicted to Diesel
cowboyupamrka's Avatar
Send a message via AIM to cowboyupamrka Send a message via Yahoo to cowboyupamrka
mine is stock minus the 4" turbo back and it is 4" right behind the turbo. no problems here. gotta love the sound it makes now
cowboyupamrka is offline
post #7 of 9 Old 11-04-2007, 09:58 PM
Did you ever tow with it and did you notice a difference in spool up while under load?
post #8 of 9 Old 11-04-2007, 10:20 PM
Addicted to Diesel
nope. it seemed to pull better with the exhaust. up hill was about even with stock exhaust, but take off seemed much better and easier for it. as you know i was puuling our pull tractor around. i had it on for the bishop pull so it got some good hills between there and bakersfield.
post #9 of 9 Old 11-04-2007, 10:33 PM
Now I know you. Of course. You pulled the tractor up to Reno as well and up to that pull before Reno in BFE, Nevada.
Thank you for the info on the exhaust. I can't wait until next pulling season. I got my truck done. Look at my signature for my latest dyno and drag strip times. I have turned up the fuel since then, this wednesday I go to the track again.
