AIR FILTER HOSE MELTED!!!HELP - Ford Powerstroke Diesel Forum
Old 11-04-2007, 02:12 PM
Turbo made a strange noise yesterday as if it was surging. Took the boot off and I discovered all this...
What is that green line in there??
Turbo fins seem fine but did move a small amount. Time for a new WW?
What to do about the intake?
AIR FILTER HOSE MELTED!!!HELP-intake-hose.jpg   AIR FILTER HOSE MELTED!!!HELP-100_1309.jpg   AIR FILTER HOSE MELTED!!!HELP-turb-wheel.jpg
Old 11-04-2007, 02:15 PM
Desert Shield/Storm Vet
Wow big hole. The green line is part of the wastegate solenoid it read pressure differential between the intake and y-pipe to control the wastegate. Is your movement laterally or in and out?
Old 11-04-2007, 02:29 PM
Laterally. Not much but did feel a little bit. I am supposed to drive it a town over to get it aligned tomorrow but I dont even want to start it up because of the intake hose. Of course I need a new hose but if I where you would you order a new pipe from AEM?
Old 11-04-2007, 02:31 PM
As long as its not excessive you should be okay just keep an eye on it.
Old 11-04-2007, 02:37 PM
I mite rap it in good ole duct tape until I can go order a new hose. I guess it just got to close to the valve cover
Old 11-04-2007, 02:39 PM
Could that green line may have caused the turbo to make a strange noise?
Old 11-04-2007, 02:40 PM
Man I would be really carefull in doing that. I would get a new one as soon as possible as you don't want to be sucking dust and dirt into your turbo or your engine for that matter.
No. What did the noise sound like? Probobly was from the hole in the intake.
Old 11-04-2007, 02:48 PM
Like a sick turbo...dont mean to sound smart but I dont think I could ever make that noise. It was kind of like a bad suction and hissing noise. You know when your trucks real cold and its cold outside and it makes that kkkkkkkk noise. Kinda like that iono
Old 11-04-2007, 02:50 PM
Yeah more than likely from the hole in your intake I would bet
