What to do for affordable RR/ fuel system - Ford Powerstroke Diesel Forum
Old 01-04-2013, 08:07 PM
I have a 00 with 14500 miles, built auto, cold air intake, newly installed 4 inch exhaust, and Edge EVO set on the low tow safe setting until I install my gauges. I have recently noticed a VERY slight knock sound at idle, only when up to full operating temp. and goes away after ~1500 rpm~. i have had a trusted psd tech look at it and run scans and he says he cant hear it but if it were anything he thinks it would be the number 8 cyl. starving. My question is can i get by with something like the FRx from riff raff diesel. Will this sufficiently fix the dead head issue or would it be a waste of money? I have done some research and I thought it looked decent for the price. I have future plans for higher HP but I am on a budget. Thanks for the input.
Old 01-04-2013, 10:07 PM
i just built my own RR fuel system. pretty straight forward... took a bit to get all the parts together when piecing it out but doable.
Old 01-05-2013, 05:25 AM
Feedback Score: 5 reviews
DIY or don't stop go direct to a Strictly kit...
Old 01-05-2013, 05:40 AM
Yes. Frx will work. Maybe want more when you go to bigger sticks. It does the same thing as rr, just not as accurate due to a spring determining pressure(same as stock).
Old 01-05-2013, 06:44 AM
Yes it would be until i go with bigger sticks. Since it comes with different springs for different psi, What psi do you guys recommend and will psi have an effect on Mileage?
Old 01-05-2013, 06:50 AM
They recommend which one to use(gold i think).
Get a real RR and fuel bowl delete...don't go cheap when it come to providing clean fuel.
Old 01-05-2013, 06:53 AM
I agree rr is the best bet but how is it "going cheap"? It is basically still factory setup
Old 01-05-2013, 06:58 AM
Exactly, I just want to upgrade and protect the injectors with whats there already. I plan to do everything when I do sticks. I am just on a very tight budget right now
Old 01-05-2013, 07:06 AM
Also, gomer, did you notice any difference in perf. or mileage when you installed yours?
