Diy mods
I've had an 01 7.3 6spd for a year and a half. about to turn 200,000mi. I want to do some mods but have little to nothing for a budget. I'm going to delete my cat. and modify my intake first. Been seeing some diy intake mods and was wondering if anyone had any more ideas on how to get more air without just buying a new intake. I would appreciate any ideas
zoodad mod helps get cooler air into the intake. also a metal box around the intake if you do a 6637 with 5" sides will help to defect engine heat.
what exactly is the zoodad mod. and where would you get the 6637. is that a tymar filter?
You can get them at most any parts store. I got mine at napa for $35 ??
Zoodad is just a matter of cutting a hole in your header panel to allow for more cool air |
Use google and a few key words, "powerstroke, zoodad, 6637".
Do some searching and reading before you ask away. The answers are out there. |
yep... asked over and over and over again. search is your best friend on this site.
thanks for the info
and advice. appreciate it. I'll hit the books.:-)
did the zoodad mod.
used two layers of mason's lathe to cover hole. also cut out a chunk of my stock intake housing to open it up a little. 6637 and modified heat shield coming next. thanks again
