Hubs need to be greased?
Here's the issue... I cant turn the hubs from lock to auto, the transmission will run up to 2500 rpms before it will shift, there is constant boost(6psi) when cruising at like 60(and 1900rpms) and when I let off the throttle, even down hill, the truck decelerates very quickly, especially above 50mph. Oh and of course, truck has no balls going forward. Do I need to grease/clean the hubs? Or do I have a bigger issue? Anyone know the best way to remove and clean them? Any input is much appreciated
So basically your hubs are locked and you are in 4X4?
Seized callipers will cause mileage and drive issues. You may want to pull them off and grease everything up. |
The hubs are on auto, the 4x4 engages, disengages and works fine, but I cant turn the hub by hand(or with vice grips) from auto to lock, and there is something causing some serious drag
Your manual mechanism of the hubs probably just need cleaning and lubricating, but they should not be the cause of the problem. Your hub assembly could be the cause of the original issue pertaining to decelerating, etc.
Jack the front of the truck up either one side at a time or both and grab the sides of each will and wiggle. Grab the top and bottom. Both times check for movement. Top and bottom may need a pry bar to check for movement. Are you hearing any humming for noise coming from the front while driving? |
since this only happens in 4x4 you will likely be looking at a differential or transfer case issue
if your one hub wasn't fubared it would be easy to diagnose If I were you i would lift the side with the good hub and when not in 4x4 spin the tire and see how easily it turns then lock the good hub and see if it's a huge fight to turn if neither hub is good and you can't select 4x4 manually We can try just using the transfer case in 4x4 by blocking the vacuum signal to the hubs Last edited by ZMANN; 01-04-2013 at 06:36 AM. |
No nosie that I can hear, but that doesnt mean there isnt one. Ill jack it up this weekend and check, I just had an alignment so none of the front end parts are bad, I dont notice a hub being bad in the steering wheel. I got a feeling that the wheels aren't going to want to turn easily when in the air. I heard something about greasing it through the abs port? I guess it could be bad bearings too? But there's no noise from the bearings which is why im leaning away from that.
well if your unit bearing was bad it would be bad in 4x2 also and you would have the boost and slowing issue all the time
yes u can grease them through the ABS but if a hub was that far gone it would be to late |
My apologies, all these symptoms are happening in 4x2, my 4x4 engages, and disengages just as it should because the front hubs are set on auto, and stuck there. Im not having any issue with 4x4 really, its just the drag that something is creating thats killing the truck and making everything work harder than it should. Might not even be the hubs? Ill have to see how freely they wheels spin when up in the air
