OEM keyless won't unlock after sitting overnight??? - Ford Powerstroke Diesel Forum
Old 01-02-2013, 06:03 AM
Couldn't find anything with the search. Long story short, keyless works fine until the truck sits overnight. Next morning, I have to unlock manually, after I start/drive it works like normal. Any ideas what could cause this?
Old 01-02-2013, 10:43 AM
The cold can affect the door lock actuators. When it is warm, try cycling (lock / unlock) several times, if they don't work or are slow, replace you actuators. Not a hard job to do, nor is it expensive 2000 Ford F-250 Super Duty Actuator in Car & Truck Parts | eBay
Old 01-02-2013, 11:49 AM
appreciate the input. I'm not confident that's the problem . . . Reason being, the cargo light doesn't light up either. I would think if the signal is being transmitted and received, the light would come on even if the actuators didn't function???
Old 01-02-2013, 12:04 PM
How close are you to the truck? Could it be the batt in the remote is getting weak? Just asking.....
Old 01-02-2013, 01:34 PM
Are you sure its factory? LOL I know with aftermarket keyless, the GEM module will fall asleep and cause a similar issue. It has to be wired so it wakes the module up. I had that problem if I locked the doors from the switch and waited a little bit.
Old 01-02-2013, 07:23 PM
Good questions, so far it doesn't matter how close it is, even right up beside the cab. I replaced the battery just for good measure with no change.
On the OEM question, the original window sticker shows it came with it from the factory. This is the standard factory key fob too. No evidence of any aftermarket keyless entry installed.
This just started a few weeks ago, no problems (owned truck since Oct. 2011) up til then.
Old 01-03-2013, 11:54 AM
Update: This morning I tried something . . . Key fob wouldn't work so I used my key and immediately tried the fob and it worked to lock/unlock. Weird. I drove it and locked w/fob, waited 4 hours, went out and it unlocked w/fob. So it's like it is related to how long it sits.
Old 01-03-2013, 07:02 PM
Parked for 6 hours, fob worked. We'll see what happens 11 hours from now.
Old 01-03-2013, 08:50 PM
I have an aftermarket radio that would lose all its settings overnight. It turned out that the radio had to have a full time 12V supply in addition to the keyed power. I guess the radio had some sort of a capacitor in it that would lose its charge after a while and that would flush the memory.
Even though your system is factory installed it sounds like a similar kind of problem. Even if you have a battery instead of a capacitor it can still go bad over time.
Old 01-04-2013, 04:58 AM
Any thoughts on why the fob works immediately after unlocking the door manually? Possibly related to something similar to MKeeney?
