Cold weather issues - Ford Powerstroke Diesel Forum
Old 01-02-2013, 05:47 AM
Cold weather issues
When ever it gets below 20 degrees outside its like the ebpv gets stuck or something. I have very low power and high egts. Then like a switch flips it takes back off and runs fine. Or shut truck off and restart then it will be fine. What is causing this to happen. I just cleaned the tube and back pressure sensor to. It did it before this and after.
Old 01-02-2013, 05:48 AM
My ICP was bad and just replaced it. A new cps sensor will be here soon and doing that also.
Old 01-02-2013, 06:00 AM
It is probably turning off when the truck warms up. So you can either let it warm up or delete it.
Old 01-02-2013, 06:26 AM
Send a message via AIM to rufushusky
Sounds like your EBPV is doing its job...
Winter Operation, Hard Starting, Hissing Sound Etc...
Old 01-03-2013, 04:57 AM
Ok I keep getting told its doing its job but I had a 7.3 before that I had no issues with it.I just can't beleive after its plugged in all night and let it idle for 5 mins I still can't take off without it still being closed. Heck yesterday I let it warm up basically till normal running temp then drove down the road to the shop. I shut it off for 10 min went back out temps were still high didn't drop much and I could hardly take off cause that damn thing was closed again.
Old 01-03-2013, 06:02 AM
It could very well be sticking. I don't know of a way to possibly fix that other than pulling it off and cleaning/checking it out. I personally don't miss mine at all. Way too loud unless you live in the country.
Old 01-03-2013, 07:53 AM
I disagree..... You have not met my neighbors, it's not loud enough.
Old 01-03-2013, 02:53 PM
take your downpipe off and see if the valve is moving freely and fully, if its not i'd wire it open and forget about it till spring..less you have a garage
Old 01-04-2013, 05:09 AM
Well for now I just unplugged it to see if that will work. I guess in near future a delete will be put in.
Old 01-04-2013, 05:57 AM
7.3 4 Ever! Nothing else!
Feedback Score: 7 reviews
I like mine because it warms up my truck alot faster!!!
