01 F-350 MPG - Ford Powerstroke Diesel Forum
Old 12-31-2012, 09:16 AM
01 F-350 MPG
all stock 01 F-350 4 door short box auto, what should I get for MPG? right now I'm getting 14.5-15.5. will I get more if I install a larger exhaust and air filter
Old 12-31-2012, 09:30 AM
You may see a slight increase with a turbo back straight pipe and a diy intake/aftermarket.
Couple that with gauges to monitor temps and custom tunes and you'll see another increase. During the warm season, I see around 18mpg average. During the cold it'll drop to 16.5-17mpg due to the anti-gelling additive.
Old 12-31-2012, 09:51 AM
Turbo back pipe is just what it sounds like right? How did you do the DIY air cleaner?
Old 12-31-2012, 09:58 AM
Yea, you can get a 4" for about $300ish. If you go with a 5", it'll only be 5" back from where the 4" down pipe, levels out at the bottom.
The DIY intake is basically a big tractor filter that replaces the factory air box and bolts right onto the intake. Just do a search and you'll fine plenty of info on it.
Old 12-31-2012, 11:22 AM
As far as intake goes Riffraff Diesel: Ford AIS Extended Life Filter Kit
Old 12-31-2012, 11:50 AM
what is better 4" or 5" or does it really matter? I found the DIY air filter Napa filter
Old 12-31-2012, 12:31 PM
I went with the 4" - Seems to work fine.
4" left, stock right.
Old 12-31-2012, 03:09 PM
I'd say you're about good for this time of year, mixed driving.
Scott
Old 01-01-2013, 03:17 PM
I thought they stopped making "winter blend" diesel? I thought they were all the same now year round?
