7.3 diesel pcm gone bad??? - Ford Powerstroke Diesel Forum
Old 12-30-2012, 06:07 PM
I have a 99 f250 7.3. I had put a bullydog programmer in it and wa. s just going to try it out to see if I wanted to buy it. So I did not tuck the wire coming from pcm. So I was about to drive to work and got it truck and while it was idle I accidently unplugged bully dog and truck died immediately!! Now wait to start doesn't come on, don't hear fuel pump when turning key on, and will not start. Need help please!!
Old 12-30-2012, 06:27 PM
hope you just blew a fuse. Check em all. then check the pcm connection. Then, of nothing, pull the pcm and check the pins
I made my Samsung SGH-I997 send this.
Old 12-30-2012, 06:34 PM
Question
I have checked all fuses, and pins r good and has a good connection. Does it sound like I burned it up?
Old 12-30-2012, 07:00 PM
If you're sure that's all good, then that's what I'd think
Old 12-30-2012, 07:03 PM
Any suggestions on where the best place is to get it?
Old 01-11-2013, 06:46 PM
Angry Please help!!!
Ok got another pcm and still wont start and do not have a wait to start light still!! Also do not hear fuel pump when turning key on. Help please!!
Old 01-11-2013, 07:37 PM
Did you check the fuse panel under the hood?
Old 01-11-2013, 07:50 PM
Yes I checked the one under steering wheel and under hood.
Old 01-15-2013, 09:10 AM
Wondering where you found your PCM? I am having a real difficult time finding one, from what I understand they are very specific for the vehicle? how did you track one down?
Old 01-28-2013, 09:51 PM
Rogue motors is where i got my pcm from.
